Home > Technical (L322) > How-to: Start Stop Button Replacement |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Replaced my stop / start button after reading TTB's excellent how to post, managed to source a new original button for £25 from flea bay from a guy who sells LR parts. |
5th Jul 2020 7:19am |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
Bought just the button cap part from ebay for only £8.12 including postage.
3rd Nov 2020 12:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
better than £30'ish for a whole unit.. ... - .- -.
3rd Nov 2020 1:14pm |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 |
Thanks for the guide! |
8th Nov 2020 10:04am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 397 |
It really is as simple as indicated.
29th Apr 2021 6:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
There is always potential to damage your car when working on it, the OP has shown the method and lots of people have done it with no damage and saved a lot of money.
29th Apr 2021 6:10pm |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Sorry to ask (I'm obviously a bit green) what do you mean by plug and play 5-mins? Does the system have to accept the new item? Do you attach new item and wait 5-mins before it will work? I recently tried changing my split original button for an Ebay LR050802 button (got some Chinese hieroglyphs on it) and expected it to operate right away - and it didn't - and assumed it was broke in post... Do you have to wait 5-mins until it works then?
18th May 2021 7:35am |
Sorry but what do you mean by 5-mins plug and play? Does the system take this long to recognise the component before it will operate? |
19th May 2021 8:38am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
The switch should work straight away, the concept of 5 minutes plug and play is just a reference to the fact it's an easy repair 2011 TDV8 Vogue SE |
19th May 2021 9:00am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Very informative, just waiting for my Chinese button cover to be delivered, a lot cheaper than a full unit |
19th May 2021 9:15am |
Yes my Chinese variant (Ebay peep said it wasn't but it was) switch was £30 and it didn't work after trying cracked old and new new, three times swapy swapy at least, using my trusty thick plectrums to pop out unit first. I got my money back after mentioning feedback critique and also have a non working Chinese switch to boot, which they didn't want back. The Chinese one seems to have one less metal connector at plug point than the original, which might be why no worky worky?!? |
19th May 2021 12:55pm |
I'm dumb sometimes... A lot actually My local LR/RR '''''''specialists''''''' suggested two hours to change this button: |
19th May 2021 12:58pm |
I extracted my stop/start button unit using three sturdy (thicker) guitar plectrums gently guided down the edges of the button unit where the three securing tabs are located, and carefully prising unit out this way, saving using screw drivers and such. There are soft plastic tools available for just such a job/task, which many garages use just for this job. You just have to be aware of where the securing tabs are located. |
11th Jun 2021 8:26am |
Unnecessary quote removed
11th Jun 2021 8:38am |
