![]() | Home > Technical (L322) > How-to: Start Stop Button Replacement |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Replaced my stop / start button after reading TTB's excellent how to post, managed to source a new original button for £25 from flea bay from a guy who sells LR parts. |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Bought just the button cap part from ebay for only £8.12 including postage.
It may be possible to replace this part in situ but as I didn't want to damage or scratch anything I removed as described earlier in the thread. I separated the inner part of the switch by pressing in the tabs shown down the inside of the chrome outer.
I then removed the inner bezel to avoid damage too by gently prizing the tabs shown.
Couldn't get the whole of the inner button out so gently prized cap as shown. ![]() Reassembly is reverse, looks a bit better now especially for only £8.12 and 1/2 hour messing. ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
better than £30'ish for a whole unit.. |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 ![]() ![]() ![]() |
Thanks for the guide! |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
It really is as simple as indicated.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
There is always potential to damage your car when working on it, the OP has shown the method and lots of people have done it with no damage and saved a lot of money.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Sorry to ask (I'm obviously a bit green) what do you mean by plug and play 5-mins? Does the system have to accept the new item? Do you attach new item and wait 5-mins before it will work? I recently tried changing my split original button for an Ebay LR050802 button (got some Chinese hieroglyphs on it) and expected it to operate right away - and it didn't - and assumed it was broke in post... Do you have to wait 5-mins until it works then?
Sorry but what do you mean by 5-mins plug and play? Does the system take this long to recognise the component before it will operate? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
The switch should work straight away, the concept of 5 minutes plug and play is just a reference to the fact it's an easy repair |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Very informative, just waiting for my Chinese button cover to be delivered, a lot cheaper than a full unit |
Yes my Chinese variant (Ebay peep said it wasn't but it was) switch was £30 and it didn't work after trying cracked old and new new, three times swapy swapy at least, using my trusty thick plectrums to pop out unit first. I got my money back after mentioning feedback critique and also have a non working Chinese switch to boot, which they didn't want back. The Chinese one seems to have one less metal connector at plug point than the original, which might be why no worky worky?!? |
I'm dumb sometimes... A lot actually ![]() My local LR/RR '''''''specialists''''''' suggested two hours to change this button: ![]() ![]() |
I extracted my stop/start button unit using three sturdy (thicker) guitar plectrums gently guided down the edges of the button unit where the three securing tabs are located, and carefully prising unit out this way, saving using screw drivers and such. There are soft plastic tools available for just such a job/task, which many garages use just for this job. You just have to be aware of where the securing tabs are located. |
Unnecessary quote removed
