Home > Technical (L405) > L405 - Restricted Performance - EGR Valve |
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 84 |
Hi Hawkeye,
10th Jun 2021 12:25pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
where are the pics? 2012 Vogue 4.4 TDV8 - Current
10th Jun 2021 12:30pm |
hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23 |
Pics are in the gallery - sorry ..... should probably have inserted them directly into the post!
10th Jun 2021 12:57pm |
I'll see if I can get them for you! |
10th Jun 2021 12:58pm |
Fault Codes:
10th Jun 2021 1:18pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
As you have replaced your EGR you should now have cleaner running, judging by the state of that MAF sensor I would be worried about the soot in the intake manifold (has that been cleaned out)? It's worth checking the state of the MAP sensor also if the EGR valve was knackered, it could that the MAP vacuum is line is blocked having sucked up debris from the manifold. I would check that if they have not done so already. 2021 L405 Vogue D300
10th Jun 2021 2:39pm |
Thanks James - much appreciated & I'll pass it on. |
10th Jun 2021 4:58pm |
see this post
10th Jun 2021 6:25pm |
Many thanks James. |
10th Jun 2021 8:10pm |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
I think you can't avoid EGR clog up on a diesel car. Hence the ban on them. Carbon and NOS is diesel by product and there is no way to get around it.
11th Jun 2021 10:27am |
Thanks - I don't think my issue is this as it does not throw up these codes??? 2019 Autobiography SDV8 Byron blue/black - current 2016 Vogue SE SDV8 Santorini Black/Ivory - sold 2009 RR Sport TDV8 HSE - sold |
14th Jun 2021 10:18am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3165 |
As you are in Melksham, book it on with Steve at T & s Norman just south of Shepton Mallet. https://www.tandsnorman.com
14th Jun 2021 10:40am |
Love it - many thanks! |
14th Jun 2021 12:35pm |
PC76 Member Since: 28 Oct 2019 Location: Home Posts: 10 |
Hi Hawkeye,
13th Jan 2024 11:47pm |
