![]() | Home > Maintenance & Mods (L405) > door flap broke off on trailer electric plug socket |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1215 ![]() ![]() ![]() |
I would think that the socket is now scrap if the plastic hinge points have broken.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I agree with Merchy. That's the way I'd tackle it also. Kev
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
It’s not scrap. I used the socket this past weekend with the broken flap. Only the flap/door that coveres the socket and swings open is bad. It’s the OEM LR unit so I want to replace/keep it OEM. 2014 FF Autobiography 5.0 SC
I will re-phrase, the electrics may still work, BUT if the flap / hinge cannot be repaired then the wiring is open to the elements when a trailer is not attached, thus to me, it would then require immediate replacement.
It may be Westfalen you’re right. The flap/door does say Land Rover on it but it’s probably just rebranded.
Flyingscotsman1 Member Since: 02 Mar 2021 Location: buckinghamshire Posts: 26 ![]() ![]() ![]() |
I have the same Autobiography mine is Weasfalen retractable tow bar coat my socket in Vaseline as keeps out water and makes for easy connection of the plug I think you can get the parts from L R to repair it its a German two bar but made in China I think |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
I had this and bought a s/h trailer socket loom on ebay for £20 and just swapped over the plastic shells. L322 2007 TDV8 3.6 |
mines not a retractable its a fixed tow bar. But the issue is the electronic socket/flap for the trailer electronics. Did I read right you have vaseline in your socket? 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
do you happen to have a link? Unfortunately, I cant see pictured here at work if you posted one. 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
