Home > Maintenance & Mods (L405) > door flap broke off on trailer electric plug socket
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
so the spring loaded door has plastic hinges....great design RR I know.....well I hooked up my boat trailer lights and the plastic door hinges broke so it fell off and leaves the socket exposed. Is this replaceable without buying the whole unit? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #595227 24th May 2021 6:48pm
Merchy
I would think that the socket is now scrap if the plastic hinge points have broken.
The plastic wiring socket assembly complete with hinged flap are easy and cheap to buy. Just get a good quality named brand then change over, not a big job. Probably under $20 / $25 from the interweb Sir. Thumbs Up
Post #595229 24th May 2021 7:16pm
knwatkins
I agree with Merchy. That's the way I'd tackle it also. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #595239 24th May 2021 8:05pm
horse86
It’s not scrap. I used the socket this past weekend with the broken flap. Only the flap/door that coveres the socket and swings open is bad. It’s the OEM LR unit so I want to replace/keep it OEM. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #595245 24th May 2021 8:31pm
Merchy
I will re-phrase, the electrics may still work, BUT if the flap / hinge cannot be repaired then the wiring is open to the elements when a trailer is not attached, thus to me, it would then require immediate replacement.
LR never made most of their own towing parts, there maybe LR numbers on some bits, but they are from companies like Westfalia etc. So for instance if the tow bar is a westfalia design then you can source a new socket complete with hinged flap from Westfalia or which ever makers towbar you have, and transfer the wiring from one to another and stay as you quote OEM
Post #595246 24th May 2021 8:48pm
horse86
It may be Westfalen you’re right. The flap/door does say Land Rover on it but it’s probably just rebranded.
I’ll have to see what the socket runs if I have to replace it...was hoping I could just replace the flap. It’s a crap design...plastic hinges SMH 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #595254 24th May 2021 11:48pm
Flyingscotsman1
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
I have the same Autobiography mine is Weasfalen retractable tow bar coat my socket in Vaseline as keeps out water and makes for easy connection of the plug I think you can get the parts from L R to repair it its a German two bar but made in China I think
Post #596864 8th Jun 2021 7:25pm
Chris1573
I had this and bought a s/h trailer socket loom on ebay for £20 and just swapped over the plastic shells. L322 2007 TDV8 3.6
Post #596897 9th Jun 2021 6:53am
horse86
mines not a retractable its a fixed tow bar. But the issue is the electronic socket/flap for the trailer electronics. Did I read right you have vaseline in your socket? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #596927 9th Jun 2021 1:16pm
horse86
do you happen to have a link? Unfortunately, I cant see pictured here at work if you posted one. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #596928 9th Jun 2021 1:17pm
