Home > Maintenance & Mods (L405) > Bonnet boot lettering template solutions? L405
pld118
I’ve ordered Powerful UK bonnet and boot RR lettering.
Someone said the Powerful supplied template is based on a RRS and isn’t much use (by my reading).
What tips/ alternatives are there for a good template please including making your own please?
Thanks 🙏
Post #596447 5th Jun 2021 7:56am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Cut the template between each letter then place over existing letters before removing them. Tape template back together in new spacing- hey presto, perfect spacing. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #596555 5th Jun 2021 9:38pm
pld118
Thanks... No clue as to how to do that but will give it some thought 😂👍🏻
Post #596559 5th Jun 2021 9:51pm
pld118
The Powerful UK front and rear letters and template arrived 48 hours after being ordered (£48 incl delivery). Good quality letters 👍🏻
The templates front and rear are both marked L405 on the template, not RRS.
The supplied rear lettering template spacing seems identical to the letter spacing that’s on our existing tailgate lettering.
The supplied front lettering template is identically spaced to our existing lettering but for the last two letters (ie the E and the R). They’re half a centimetre or so out when the new template is overlaid with the existing lettering, but… the main dealer actually replaced our front bonnet lettering 3.5 years ago and I wonder if maybe they didn’t space the last two letters ‘quite so’ back then. Not a big issue either way and easily dealt with methinks Thumbs Up
Does anyone know if the Powerful UK lettering adhesive is up to the job or if I should change it?
Post #596828 8th Jun 2021 5:42pm
I'd put them on as per instructions Ryan.. I'm sure if you have any problems powerful will look after you... ... - .- -.
Post #596841 8th Jun 2021 7:00pm
pld118
Thanks Stan, will do that then… impressed with the Powerful service and their products do seem good quality 👍🏻
Post #596848 8th Jun 2021 7:16pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Just fitted there rear range rover badge on my car because the previous owner had fitted chrome letters Rolling Eyes . Tried the powerful template over the existing letters before removing them and they were totally different to the template
So I removed the badges and the sticky glue/tape and spent about 30mins buffing the panel to remove all trace of the old letters. Then wiped the panel with the alcohol wipe supplied with the kit. Had about 5 attempts at fitting the template before I was happy with the positioning and managed to cover a couple of small chips. Luckily the template is not too sticky and easily fitted/removed as many times as you need
My car had been sat in direct sunlight all day so the rear tailgate was nice and warm when I stuck the letters on. I always think they stick better when heated slightly
 Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #596849 8th Jun 2021 7:16pm
pld118
Looks a neat job 👍🏻 Like the colour of the car too 👍🏻👍🏻
Post #596851 8th Jun 2021 7:26pm
marsie
Thanks. It's loire blue Thumbs Up Paul
Post #596869 8th Jun 2021 8:49pm
ash83
United States
You used this template?
I had the panel resprayed and need to put the emblems back on
https://www.powerfuluk.com/collections/l49...sport-l494
Post #714960 27th Mar 2025 6:30am
