Home > In Car Electronics (L322) > BCM Swap
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
BCM Swap
Hi All,
Has anyone swapped a BCM from one car to another?
If so what are the Pros/Cons?
I know a new BCM can be bought and coded to a car but why do people not swap in a BCM from a scrapped car?
Thanks,
Post #596723 7th Jun 2021 1:58pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Not sure which one you have but I don’t think they need to be programmed to another car. I bought one and fitted it myself. I take it it’s the body control module which sits under the pax seat?
Post #596781 7th Jun 2021 9:01pm
Cooper1275
Hi Dolphinboy,
Yea I am getting the central locking gremlin from time to time.
I have a new battery and alternator so i know its more than likely the BCM.
I have seen them come up for sale but i wanted to make sure swapping one over wouldn't create any new headaches for me.
Did you buy a second hand used one?
Post #596803 8th Jun 2021 9:27am
Dolphinboy
yep. there are a couple of model numbers (YWC000920/21/22). I think they all work on most models. I bought a second hand one but if you can go new and original it makes sense. I ended up buying 2 as the first one made no difference (was probably kaput)
Post #596891 8th Jun 2021 11:33pm
