![]() | Home > Technical (L322) > Coolant haemorrhage lots of drips 2011 l322 tdv8 4.4 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
I’ve not heard of an oil cooler on the 4.4 leaking like that. Normally it’s oil that leaks out, or the coolant goes into the oil and vice versa.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I had my oil cooler replaced last year by a good Indy, book time is 4.5hrs & genuine LR oil cooler was £300 + vat so that gives you a rough idea of basic costs. Anything between £700-£1k should do it comfortably. I think, if you're on a budget, you can buy a pattern oil cooler [Nissen I think] for a few pounds less but that's entirely up to you.
Chieflongshin Member Since: 17 Mar 2021 Location: Uk Posts: 28 ![]() ![]() ![]() |
Definitely a bizarre one. I’ll have to look under the engine cover tomorrow and see what I can spot, I wonder if it could be a pipe let go. Engine was running fine up to me noticing, didn’t notice any smoke or smells. I have had one or two whiffs of burnt oil after a long drive but doesn’t seem to have lost any. |
The 'burnt oil smell' may well be a giveaway, mine had been leaking a while I reckon then one day I pulled into a Shell garage to fill up & smoke rising from the engine bay........that ain't good! Oil cooler was goosed, common occurrence apparently.
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 ![]() ![]() ![]() |
I've had coolant drips in that area - the O rings perish. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Does the 4.4 have the same coolant hose that runs along the V that the 4.2 S/C Petrol has? Mine failed on that and I had coolant running like your picture.
Well we are in "'lets hope the warranty covers it" territory
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
99% of oil coolers have to be replaced on these at some point.
I'm going for the suck it and get it all done approach yes. I want to forget it for another 100k. |
Well the saga continues.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Sounds like you have a decent garage doing the work, as most would just say can't do it without the part!.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Just thought I would add my story here as it may help.
I’m using a company that have some well known vehicles they’ve created.I’m pleased with their service so far. I’ve been on the end of the “my mate only charges £40ph” from friends but I want to take a heart problem to a cardiologist, not a psychologist so I’ll pay it. |
