Home > Technical (L322) > Coolant haemorrhage lots of drips 2011 l322 tdv8 4.4
Chieflongshin
United Kingdom 2011 Range Rover Vogue 4.4 V8 Barolo Black
Hi all
I had a lovely surprise last night with coolant torrent from front and back of engine. I’m guessing it’s oil cooler. I was just curious what the book time is to replace one. I’m just trying to work out how much Vaseline I’ll need for the bill. 😁
I had a look through the workshop manual but couldn’t see times in there. It’s booked in At a specialist next week so I’ll mention o rings.
Here’s a video for entertainment with it
I “think” it’s likely pooled into the vee, my driveway is inclined and as I’ve shunted it’s pushed it out both ends. I only got under car as I noticed a drive stain when I pulled up. Engines not shown any temp warnings neither low coolant however I’m leaving it on drive unused until it goes in.
[url] [/url]
Post #596437 4th Jun 2021 10:22pm
mjdronfield
I’ve not heard of an oil cooler on the 4.4 leaking like that. Normally it’s oil that leaks out, or the coolant goes into the oil and vice versa.
Might be wrong.
At least you’ve seen it.
I paid just over £1000 for mine to be fixed, at the start of 2016, though that involved 4 or 5 coolant system flushes to get rid of the oil....
I think the cooler is £300 odd to buy.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #596439 4th Jun 2021 10:43pm
Fox889
I had my oil cooler replaced last year by a good Indy, book time is 4.5hrs & genuine LR oil cooler was £300 + vat so that gives you a rough idea of basic costs. Anything between £700-£1k should do it comfortably. I think, if you're on a budget, you can buy a pattern oil cooler [Nissen I think] for a few pounds less but that's entirely up to you.
Hope this helps.
BTW like mj said, I've not heard of the coolant being dumped out like that, oil yes, but not water. Doesn't mean it hasn't happened but I would make double sure it is the cooler first.
Good luck & load up that wallet! Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #596448 5th Jun 2021 6:59am
Chieflongshin
Definitely a bizarre one. I’ll have to look under the engine cover tomorrow and see what I can spot, I wonder if it could be a pipe let go. Engine was running fine up to me noticing, didn’t notice any smoke or smells. I have had one or two whiffs of burnt oil after a long drive but doesn’t seem to have lost any.
Post #596557 5th Jun 2021 8:42pm
Fox889
The 'burnt oil smell' may well be a giveaway, mine had been leaking a while I reckon then one day I pulled into a Shell garage to fill up & smoke rising from the engine bay........that ain't good! Oil cooler was goosed, common occurrence apparently.
Let us know what happens & what you find. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #596573 6th Jun 2021 6:55am
Chieflongshin
Had a further dig today and it looks like one part of the puzzle potentially is a hose blowing. Anyone else had similar?
Post #596634 6th Jun 2021 3:18pm
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
I've had coolant drips in that area - the O rings perish.
Post #596652 6th Jun 2021 7:24pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Does the 4.4 have the same coolant hose that runs along the V that the 4.2 S/C Petrol has? Mine failed on that and I had coolant running like your picture.
I'm not familiar with the 4.4 TDV8 though so I may be talking rubbish! (par for the course) Formerly happymadison1978
Post #596684 7th Jun 2021 8:41am
Chieflongshin
Well we are in "'lets hope the warranty covers it" territory
Oil cooler needs replacing
New reservoir as there is an issue with that
Alloy coolant pipe fractured at back
Oil and coolant.
I'm in two minds with this in that it's crap that it's happened but also that when it's done its one of the big jobs out the way
Post #596925 9th Jun 2021 1:13pm
DrRob
99% of oil coolers have to be replaced on these at some point.
It's a "feature" of the 4.4 TDV8 that you have to live with...
Some do just gaskets, best do gaskets AND cooler as they can warp and not sit flush.
Minor job in comparison with other issues they can have... Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #596942 9th Jun 2021 2:13pm
Chieflongshin
I'm going for the suck it and get it all done approach yes. I want to forget it for another 100k.
Post #596960 9th Jun 2021 4:07pm
Chieflongshin
Well the saga continues.
After weeks of a warranty company wasting my time with the wear and tear clause I’m no further forward. Oil cooler is being changed but a coolant pipe I need is no longer manufactured and no one has it in stock in uk or Europe from what I can see. Garage has been superb and is going to fabricate something as the original is unrepairable but trust me to buy the Range Rover with the part where the manufacturer is under consultation and they can’t get it.
Hopefully it’s sorted soon
Post #599034 28th Jun 2021 7:37pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Sounds like you have a decent garage doing the work, as most would just say can't do it without the part!.
As a note, Manufacturers only need to have parts access / supply for 10 years. Whistle
Post #599036 28th Jun 2021 7:49pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Just thought I would add my story here as it may help.
4.4 TDV8
Day or so after buying it Coolant low warning.
The fan was hitting a coolant pipe and had rubbed through.
I cut out the split bit and replaced with a section of tube.
Also bent the metal splitter as that must have been what caused the pipe to be so close to the fan.
Fast forward a year or so...
Yesterday after a 100 mile journey I got coolant low again.
Had a look today and there were signs of a leak at the 2 pipes in and out of engine to heater system. (The ones with quick release clips on them)
I replaced the clamps with jubilee clamps and it quickly became apparent the plastic had gone brittle and they broke.
Easy to see with engine cover off but worth keeping an eye on.
It looks like the plastic part is only available with complete pipe. 1 is double the price of the other. However I am certain the plastic part is identical.
Post #599037 28th Jun 2021 8:01pm
Chieflongshin
I’m using a company that have some well known vehicles they’ve created.I’m pleased with their service so far. I’ve been on the end of the “my mate only charges £40ph” from friends but I want to take a heart problem to a cardiologist, not a psychologist so I’ll pay it.
Post #599066 29th Jun 2021 5:15am
