![]() | Home > Maintenance & Mods (L405) > Roof rails for L405 |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
I am looking for some roof rails form my new (to me) L405. Has anyone fitted the Powerful.uk ones, and if so do they use standard cross bars |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
I see they states these are not for vehicles with a panoramic/glass roof. What’s the reason behind that? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35621 ![]() ![]() |
https://www.fullfatrr.com/forum/topic57118...roof+rails
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
Would be interested to hear what Powerful say about the pano roof as I'm in exactly the same boat |
Hmm, didn't read that bit because mine has an pan roof. Will contact them again to seee what they say |
Had a message back from powerful saying their bars won't fit with pan roof models. I have found another seller on eBay that says theirs fit with pan roof or not and they are cheaper than the powerful ones
Will do, going to ring landrover tomorrow just to price genuine ones up through my trade account |
will_warne Member Since: 04 Aug 2014 Location: London / Oxfordshire Posts: 45 ![]() ![]() ![]() |
I have the Powerful ones fitted and have a pano roof - the quality of the bars is reasonable, if not amazing. I suspect the reason they say they are not suitable for fitting to pano roofs is because there is always a risk of the roof cracking and they don't want the risk of an argument that the glass broke because of the bars. Ultimately, the genuine bars are the same for both the pano and non-pano models, with the only difference being the trim strips. As the powerful ones are compatible with genuine roof bar trim strips, I concluded that they should work regardless of whether or not you have a pano roof.
Thanks Will, I have spoken to several people who have fitted powerful ones to pan roof models with no problem. Not sure of their reason for stating "not for panoramic roof models". After all I would say the majority of L405 had a pan roof |
Finally got round to fitting my roof rails. Fairly straight forward job, took about an hour
2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
This is number 1 priority job for me so I can transport my Oztent! - so thanks for sharing, they look great. Just to confirm, these are Powerful UK ones then? Did you drill the existing finisher strips? FFRR SDV8 Autobiography |
No these were from eBay
Perfect - I'll buy a set |
Yes, on the powerful vid they use a 22 but had to file it out. i did mine with a 25mm I got them spot on so didn't need to file them. Its only very thin aluminium so drills very easy |
