Home > Technical (L405) > Select CCF Operation Failing with Newly Edited File
garrettwp
United States 2017 Range Rover TDV6 Corris Grey
I've been able to use a CCF editor and push my changes to my 2017 L405 without issue until the other day. I finally wired in a ACC radar and went to enable adaptive cruise and the Select CCF routine fails almost immediately. I checked the Pathfinder logs and saw the error listed below. What's odd is that my current file will push to the vehicle without issue - this file has been edited dozens of times so it's very confusing as to what is the cause. Please respond or PM if you can help!
av - Error executing flow
java.nio.BufferUnderflowException
at java.nio.Buffer.nextGetIndex(Buffer.java:500)
at java.nio.HeapByteBuffer.get(HeapByteBuffer.java:135)
at com.avl.ditest.dicore.diflow.flash.VBFHeaderParser.a(SourceFile:9Cool
at com.avl.ditest.dicore.diflow.flash.VBFHeaderParser.parse(SourceFile:27)
at com.avl.ditest.dicore.diflow.flash.FlashDataVBF.a(SourceFile:77)
at com.avl.ditest.dicore.diflow.flash.FlashDataVBF.getSegments(SourceFile:54)
Post #596129 1st Jun 2021 8:37pm
A quick email to Patrick @GAP would be your best route to a solution Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #596167 2nd Jun 2021 12:14am
Patrick/GAP don't cover "Pathfinder or post 2017 models" Alan...
Post #596168 2nd Jun 2021 12:31am
garrettwp
I resolved it but starting with my original CCF file and re-applying all the changes. It must have gotten messed up somehow.
Post #596169 2nd Jun 2021 2:05am
Mikey
Yes they do...
Post #596174 2nd Jun 2021 7:30am
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Come on Mikey - that is a bit cryptic.....
Are you saying that if I ask Patrick nicely he'll let me play with the CCF on my MY'17?....
W. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #596311 3rd Jun 2021 5:01pm
Mikey
G3 tool is required. We've just upgraded Thumbs Up Mr. Green
Post #596314 3rd Jun 2021 5:23pm
