Home > In Car Electronics (L322) > 2004 L322 Vogue HU Issue
WellDrivenJames
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
Good morning,
My 2004 Vogue Head Unit has stopped working properly as of the weekend. It all worked fine on Thursday, and then on Friday (just as we were starting a long drive) the screen came on and the Nav worked fine but the amber light does not come on by the volume knob and there is no sound and also the DSP option is now missing from the menu screen?
Any ideas what may be causing this? Is it the main head unit in the dash or the DSP unit in the boot that could be faulty?
Thanks '04 Adriatic Blue Td6 Vogue
Previous - '96 P38 DSE, '07 D3 HSE, '09 FL2 HSE, '00 FL1 (and many non-LR cars over the years!)
Post #596054 1st Jun 2021 8:06am
WellDrivenJames
I just went out to investigate a bit more and when I disconnected the DSP I noticed the connectors were a bit moist, not wet, but just a bit damp and the residue was a bit dirty. I gave them a quick wipe and plugged them all back in and the amber light on the screen unit still not light up and now the backlight of the screen comes on but no graphics. I have now disconnected the DSP to leave to air a bit and then I'll give the connectors a proper clean and then refit this afternoon to see if that helps, otherwise, I feel a new unit or DSP repair job is in order. '04 Adriatic Blue Td6 Vogue
Post #596073 1st Jun 2021 9:51am
mjdronfield
An option will be grey on the menu screen, and then removed if the unit does not identify itself on the ibus.
The problem will be in the boot, the head unit is just a front end.
Water ingress is a common issue. You will need to make sure the units are fully dry and connections good.
Land Rover did a “water shedder” to help with the issue. It’s just a plastic bag that goes behind and over the units....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #596076 1st Jun 2021 10:02am
WellDrivenJames
Thanks.
Yes it certainly looks that way. Although I am a bit puzzled as to why the slave screen has now stopped showing any graphics but hopefully when everything has dried out it should work. '04 Adriatic Blue Td6 Vogue
Post #596081 1st Jun 2021 10:40am
mjdronfield
I think thats fed from the Sat Nav unit. It might have defaulted to something strange with the DSP not there.
Or it’s connections damp also. You need to dry that corner of the boot if you can.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #596083 1st Jun 2021 10:46am
WellDrivenJames
The option has completely gone from the home screen, does that mean that the DSP is not working at all? I have also now noticed a greyed out "Code" option the home screen now as well. '04 Adriatic Blue Td6 Vogue
Post #596099 1st Jun 2021 1:15pm
mjdronfield
The DSP has not identified itself on the ibus network, so removed from the menu. If you can get it going, it should reappear. Helps your troubleshooting at least. I can’t remember the colour of the ibus wire. Might be white or white and something. The Workshop manual is available for download in the Wiki.
The Code is used so you can set a 4 digit pin, so the car won’t start unless the pin has been entered. I can’t remember if that is always grey or not, but can only be set with the engine off. I wouldn’t worry about that at the moment.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #596107 1st Jun 2021 3:23pm
WellDrivenJames
It looks like the DSP is dead so I'm going to send it off for repair.
I have thought about a full stereo replacement for something aftermarket that would work with CarPlay etc, but I've always preferred things to stay as original as possible and as this car is 100% how it was when it came out the factory, I just can't bring myself to change it.
Hopefully a repair job will do the trick. '04 Adriatic Blue Td6 Vogue
Post #596266 3rd Jun 2021 8:39am
mjdronfield
Baris on here can do repairs if you are stuck. And amp upgrades... all on the stock units...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #596275 3rd Jun 2021 10:29am
Danwilderspin
What are you quoted for a repair?
They go for £100-150 on eBay so don’t get ripped off. You can repin to the non dsp amp too not far off same power and speakers less agro, or as I said aftermarket amp.
As I’ve said before it’s nice to keep it stock but you will be replacing a knackered nav drive, phone module, screen going green, amp going bang, changer every year. I would gut it and get the ibus interface on your year that will surpass the car integration that it has coupled with a nice erisin 10.25 head unit for £200 and maybe an amp.
You could if you really wanted keep all the old system bits safe and look for a bargain amp so when you sell it you have all the stock bits. Personally I didn’t . Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #596370 3rd Jun 2021 10:49pm
