![]() | Home > Technical (L322) > High Pitched Squeal on Hard acceleration Only |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1226 ![]() ![]() ![]() |
I don't really know these engines, BUT if it only when you suddenly accelerate harder, as opposed to gentle acceleration, and you have no other faults / problems / codes, then check the belts and pulleys for various drives, before you start pulling parts off. Hope this helps..... |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Gearbox clutch packs or torque converter slipping? |
Snicknack Member Since: 26 Jan 2021 Location: Cumbria Posts: 12 ![]() ![]() ![]() |
Surely I could replicate these in neutral without drive as they're fixed belts. Which I've tried... What do you think? |
You could be right about testing whilst in neutral, but then engine is not under load.
I've found this video which is very similar sounding,
You could always sell the smoke tester after, there would probably be someone on here who would buy it.
Been talking to a local independent who has experience. Best indicator so far is that the inlet manifold is a common problem with leaks and cracks, carbon and soot will build up on the problem area. Will be taking the inlet off for inspection as its only an hour Job. |
