Home > Technical (L322) > High Pitched Squeal on Hard acceleration Only |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
I don't really know these engines, BUT if it only when you suddenly accelerate harder, as opposed to gentle acceleration, and you have no other faults / problems / codes, then check the belts and pulleys for various drives, before you start pulling parts off. Hope this helps..... |
27th May 2021 11:29am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Gearbox clutch packs or torque converter slipping? |
27th May 2021 11:44am |
Snicknack Member Since: 26 Jan 2021 Location: Cumbria Posts: 12 |
Surely I could replicate these in neutral without drive as they're fixed belts. Which I've tried... What do you think? |
27th May 2021 11:59am |
You could be right about testing whilst in neutral, but then engine is not under load.
27th May 2021 12:12pm |
I've found this video which is very similar sounding,
27th May 2021 12:54pm |
You could always sell the smoke tester after, there would probably be someone on here who would buy it.
27th May 2021 1:32pm |
Been talking to a local independent who has experience. Best indicator so far is that the inlet manifold is a common problem with leaks and cracks, carbon and soot will build up on the problem area. Will be taking the inlet off for inspection as its only an hour Job. |
27th May 2021 1:44pm |
