![]() | Home > Technical (L322) > Parking sensor beeps..... |
omg! Member Since: 05 Apr 2021 Location: Fife Posts: 32 ![]() ![]() ![]() |
My sensors and reversing camera stay on for about 15 seconds after reverse has been de-selected.
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Chaps, it's neither. They will remain live until you get to around 10mph (Going forward!). The reason being is that as has already been suggested, if you're shunting backwards and forwards in a tight space, you want the system to remain live. As you're unlikely to be maneuvering once you get above 10mph the control unit then assumes you are now no longer maneuvering and switches itself off.
I guess I'm not pressing the loud pedal hard enough if it takes me 15 seconds or so to get to 10MPH! |
Ha! I reckon. |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
Right, makes sense- just annoying when I reverse into my space at home and I’m messing about doing stuff before I get ou and the thing is going mental 2009 (2010 MY) 5.0 Supercharged Autobiography
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 676 ![]() ![]() ![]() |
I have the same thing Paul and thought it might be a fault somewhere. But on the plus side, it's a good way to leave the engine on tickover while you turn it off and lower suspension to let the turbos cool down. My excuse for not find it annoying anymore and saving my engine. |
Is there no coolant circulating pump to cool the turbo's down?
Hey omg I'm very new to owning a FF l322 so I really couldn't comment on that, I'm sure some of the knowledgeable on here will be along to answer your question. I have the 3.6 and reading all the horror stories of the turbos letting go and in which no one has a definitive answer as to why some turbos decide to self destruct. As it's my first ffrr tdv8, I'm just following some simple advice I read about in here in ways to help stop the dreaded turbo failure. |
