Home > Technical (L322) > 3.6 TDV8 limp mode |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
That error code indicates problem readings when comparing MAP (intake) pressure and turbo boost pressure. Probably a leak in boosted air pressure side. You have already replaced the two problem hoses, which are the most common cause of this fault. If there is smoke showing from behind the radiator, you probably have an intercooler leak, or perhaps one of the hoses to/from it. I haven’t heard of intercooler being prone to failure on TDV8, but it is quite common on TD6.
25th May 2021 9:00pm |
Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36 |
Thanks Steve, will get some costs for replacement, cheers 2006 3.0 TD6 Vogue Black - sold
25th May 2021 9:10pm |
Patrick.weld Member Since: 25 Oct 2024 Location: Sussex Posts: 1 |
Hi,
25th Oct 2024 1:54pm |
