Home > Maintenance & Mods (L322) > Factory tints or not?
Frubes
United Kingdom 2010 Range Rover Autobiography TDV8 Nara Bronze
Finally got my FF RR. 2010 Nara Bronze with espresso leather autobio.
It's got tints in the back. I assumed they were factory fit. I noticed the back passenger window tint has a few scratches and a hole where it's peeled.
I had read the factory tints were in the glass so can it scratch and peel?
Id rather take them off. But look at the other windows I can see where I'd start, no edges nothing. So are they factory and stay or add on and removable?
Post #595063 23rd May 2021 11:05am
Rob99
Easy way to tell is to look at the rear boot quarter windows. If you can see the copper colour wires on the glass then it will be aftermarket tints. Factory ones aren't filmed, the glass itself is tinted. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #595066 23rd May 2021 11:40am
Frubes
I'm pretty it is filmed as there's a few nicks in the rear windows. I can't see any edges at all though. Why they have had the glass out to film it? I don't want to start pulling it if I can't get it all off
Post #595068 23rd May 2021 12:15pm
mjdronfield
Sometimes, you just have to be brave.....
As above, if you have bits that are peeling it will be a film, and some fitters are better than others.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #595074 23rd May 2021 1:02pm
Merchy
There a few videos around to help remove the tint film, best seem to involve heat and / or steam. Which ever method you use, it looks like a long job.
Or try and see how much a tint film installer will charge as they must be used to removing it as well as installing the damn stuff. Censored
Post #595082 23rd May 2021 1:36pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
If you do decide to remove them take it very slowly and use lots of steam on the side windows with antenna on, and the rear heated screen. When I decided to remove mine from the TD6 I had loads of the silver strip peel away with the film even though I took my time and steamed them well. Regretted doing it afterwards! 😔 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #595105 23rd May 2021 5:53pm
