Home > General (L405) > What to Look for on a 2014 4.4 Autobiography
PC76
Hi all, I will be going to look at a 2014 4.4 Autobiography on Wednesday and would like to know if there is anything I need to look out for and also check any big / expensive items that should have been serviced or are soon to be. It’s got 60k on the clock.
I have my IID but it’s registered to my sport so not sure what functionality it will have to reset faults before of goo on the test drive…
Thx all in advance:)
Post #595002 22nd May 2021 3:42pm
MonkeyMan
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
I picked up a 2013 of the same model in March. To be honest I just winged it as it was from a dealer so I could reject it within a month if it had serious problems.
All I could do was test every part of the electrics, ride height settings, parking brake, entertainment system, etc. Beyond that it gets mechanical and that’s outside my knowledge.
I’ll be honest, that’s why I bought from a dealer, any suspicious noises I hear now are awesome, it’s something for them to fix before the warranty runs out.
Post #595005 22nd May 2021 4:30pm
MonkeyMan
Just to follow-up, I’m assuming that’s the best part of £30k+, so if it’s a private sale I would absolutely get it professionally checked over before buying. If you wanted a 3rd party warranty Motoreasy seem to come well recommended, and will give the car a free health check when you take out a policy. (So I would get them to check it, and if they say it’s junk, cancel the policy and walk away) For them it’s good to see (and possibly exclude) pre-existing issues. For you, it means you know what works and what doesn’t, and if it goes wrong afterwards you have a warranty.
They quoted me about £1400 for a year on my RR, but after I ignored them for 2 weeks they offered 15 months for the price of 12. Kinda tempted for when my dealer warranty runs out, or I might just put aside £2k a year and draw down from that when things need doing.
Post #595013 22nd May 2021 5:36pm
Rob99
The Wiki is your friend..........
http://www.fullfatrr.com/forum/post451066.html#451066
Good luck Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #595018 22nd May 2021 5:59pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Check out the rear tailgate rubbing on the lower it`s a known fault of out of alinement?
Post #595019 22nd May 2021 6:00pm
knwatkins
I had a couple of issues with my 2014 when I bought it last year. Nothing that wasn't easily fixed at the dealers expense. I posted a thread on it here: https://www.fullfatrr.com/forum/topic56981.html Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #595039 22nd May 2021 7:58pm
PC76
Thanks all, i will read through.
i have noted this morning that an oil leak was reported on the last MOT, is there an issue that i need to look out for with the 4.4?
Post #595141 24th May 2021 6:05am
knwatkins
Yes, the oil cooler in the V of the engine is common for leaking. It leaks down the back of the engine. Kev
Post #595142 24th May 2021 6:12am
PC76
Thanks for that. Thumbs Up
Post #595174 24th May 2021 12:02pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Try to drive it at low speed over bumps and listen for potentially expensive suspension clunks.
Check tyre wear is even.
Take your time and make sure all the gadgets and buttons work.
Put the suspension up and down and make sure it works smoothly.
Post #595198 24th May 2021 3:48pm
Boatmechanic
Sweden
Buy a 2015 or newer car
By model year 2015 (assembly date July 2014 onwards, if I remember correctly), the bugs were worked out.
Post #595244 24th May 2021 8:21pm
RR1234
2014 Range Rover Autobiography SDV8 Luxor
I had a leak from oil cooler and thermostat hosing. £1,850 plus VAT to get repaired at LR Dealership! All going well since.
Post #604286 20th Aug 2021 3:35pm
Jkay
Australia
Re: Buy a 2015 or newer car
Can anyone confirm if anything built after July 2014 “should” have all the bugs ironed out ? Keen to get back into an L405 and if so, this may widen my options a bit as I’ve only been looking at anything built Jan 2015 on
Thanks 2015 SDV8 Autobiography - Black, Cirrus, 22" Style 707 Wheels
Post #604710 25th Aug 2021 4:34am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
My 2016 MY VSE has had no issues, but more recent cars with ICT pro and later have had bugs with various bits of kit. Seems solving one issue creates others.
Post #604723 25th Aug 2021 7:21am
