Home > General (L405) > What to Look for on a 2014 4.4 Autobiography |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 |
I picked up a 2013 of the same model in March. To be honest I just winged it as it was from a dealer so I could reject it within a month if it had serious problems.
22nd May 2021 4:30pm |
Just to follow-up, I’m assuming that’s the best part of £30k+, so if it’s a private sale I would absolutely get it professionally checked over before buying. If you wanted a 3rd party warranty Motoreasy seem to come well recommended, and will give the car a free health check when you take out a policy. (So I would get them to check it, and if they say it’s junk, cancel the policy and walk away) For them it’s good to see (and possibly exclude) pre-existing issues. For you, it means you know what works and what doesn’t, and if it goes wrong afterwards you have a warranty.
22nd May 2021 5:36pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1437 |
The Wiki is your friend..........
22nd May 2021 5:59pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
Check out the rear tailgate rubbing on the lower it`s a known fault of out of alinement? |
22nd May 2021 6:00pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I had a couple of issues with my 2014 when I bought it last year. Nothing that wasn't easily fixed at the dealers expense. I posted a thread on it here: https://www.fullfatrr.com/forum/topic56981.html Kev
22nd May 2021 7:58pm |
PC76 Member Since: 28 Oct 2019 Location: Home Posts: 10 |
Thanks all, i will read through.
24th May 2021 6:05am |
Yes, the oil cooler in the V of the engine is common for leaking. It leaks down the back of the engine. Kev
24th May 2021 6:12am |
Thanks for that. |
24th May 2021 12:02pm |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 |
Try to drive it at low speed over bumps and listen for potentially expensive suspension clunks.
24th May 2021 3:48pm |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 89 |
By model year 2015 (assembly date July 2014 onwards, if I remember correctly), the bugs were worked out. |
24th May 2021 8:21pm |
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 |
I had a leak from oil cooler and thermostat hosing. £1,850 plus VAT to get repaired at LR Dealership! All going well since. |
20th Aug 2021 3:35pm |
Jkay Member Since: 12 Apr 2015 Location: Sydney, NSW Posts: 208 |
Can anyone confirm if anything built after July 2014 “should” have all the bugs ironed out ? Keen to get back into an L405 and if so, this may widen my options a bit as I’ve only been looking at anything built Jan 2015 on Thanks 2015 SDV8 Autobiography - Black, Cirrus, 22" Style 707 Wheels |
25th Aug 2021 4:34am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1031 |
My 2016 MY VSE has had no issues, but more recent cars with ICT pro and later have had bugs with various bits of kit. Seems solving one issue creates others. |
25th Aug 2021 7:21am |
