![]() | Home > Technical (L405) > Access Mode |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
its no problem doing this , in fact mine has auto access which lowers the FF when stationary.. ... - .- -.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
I always use it as default.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Dropping the car to access level may also help to deter the thieving scum from nicking the cats, as this seems to be on the increase. |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 490 ![]() ![]() ![]() |
I find that leaving it in standard height in car parks makes the doors/bodywork less vulnerable to careless Door impacts.. 2017 Range Rover Vogue V6 Diesel
It very much saves wear on the seat sides too |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
Thanks for the replies
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 910 ![]() ![]() |
The manual recommends leaving the car in Access Mode |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Always leave in access mode, same with the L322 and the RRSs before that. As Craig says, saves wear on the seat base and easier to get in. There’s also that nice feeling when you fire up the engine and press the button and feel it lift up. All part of the ownership experience for me! |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
But, but, but, if I leave it in access mode, I won’t get to feel quite as smug about my electric side steps! |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
Of course you will, as you get to lower yourself down onto the seat in a Full Fat Range Rover! |
Why not? I have deployable steps and always lower the car before exiting! ![]() |
