Home > Technical (L322) > Filling up upside down?! |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2653 |
Think it’s a quirk of the filler neck, used to do this every fill on the old l322, you are not alone lol. |
13th May 2021 6:59am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
Check inside your filler that the yellow miss fuel has not been tripped? It will trip if it has had a fill from a can spout inserted? |
13th May 2021 7:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Not quite upside down but l have turned the nozzle upwards over 90 degrees ever since l have had the car, over 10 years.
13th May 2021 7:23am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
.... then check to see if the plastic reset tool is still with the car |
13th May 2021 7:25am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
If you pull it out slightly you don't have to turn it so far, there is a sweet spot between insertion length and angle.... (ooh err Mrs..!)
13th May 2021 7:43am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Well, at least I’m not the only one then! I’ve tried the 90 degrees and no result!
13th May 2021 7:44am |
I’ll try and put the tip in and go from there.... 2009 (2010 MY) 5.0 Supercharged Autobiography
13th May 2021 7:45am |
watch you don't break your tool, they are brittle.... a long pozi screwdriver works alot better, if you shine a torch down, you'll see if the mechanism has tripped, it's quite obvious when you have light. |
13th May 2021 9:04am |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Pull out method always a winner in this house! |
13th May 2021 9:35am |
It’s worked well in this house so I’ll see if the luck continues with the car! 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
14th May 2021 5:57am |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Yep, had the same with mine, and mine hadn't had the misfuel device tripped. As has said before, I think it's just a quirk of the filler neck not venting as well as it should. Bizarrely, once I'd managed to get the tank half full I could shove it all the way in and it was fine..... Phnar phnar. |
14th May 2021 8:41am |
Interesting, I’ll try that too, maybe just need warming up before going in properly 2009 (2010 MY) 5.0 Supercharged Autobiography
14th May 2021 2:16pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Never had a problem with any of my petrol fueled cars but the Diseasel fueled S max I had was a PITA to fill up. No amount of twisting the nozzle helped! I guess it was due to the tendency for the diesel to "foam" when exiting the pump nozzle. Previous cars:
14th May 2021 4:28pm |
