![]() | Home > Maintenance & Mods (L322) > Fuel Gauge erratic |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
The suggestion (and a general rule of thumb) is to remove the negative terminal of the battery. I didn't and simply unplugged the connection to the pump, covered it in a plastic bag and tucked away..
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
It's probably obvious, but use as much fuel as you can before doing this and if you have access to a syphon/pump emptyl the rest. A set of long latex gloves (I have some for chemicals......honest) to keep as much fuel off you as possible helps with the pong. |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
I’m thinking of having a go at this on mine but it’s petrol. An empty tank (or so I’m told) is potentially more dangerous due to the build up of gasses. Any tips to help prevent us gas burners to stop blowing our heads off?! |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Ok first the pins dint show any resistance, then after cleaning with air spray n few more tries.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
So I did this fix over the last couple of evenings. Some observations to compliment what has already been said:
Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51 ![]() ![]() ![]() |
Also completed this surgery on my car this evening in the darkness of Scotland. One tip I would recommend is to crimp the ends onto the short wire sections that are within the main harness housing. Then crimp on the longer wire sections that come from the passenger side sender unit. I only changed one connector and this has fixed my issue. I must have only had 10 litres or so left in my tank. |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
Did the repair on my 2010 TDV8 yesterday. Just after Christmas it bonged 'no fuel' at me near home, so I didn't have to deal with any engine management initiated shutdowns, thankfully.
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 151 ![]() ![]() ![]() |
I have a similar problem with no fuel showing and distance to empty blank.
GrandVaud Member Since: 12 Feb 2021 Location: Jabreilles-Les-Bordes Posts: 1 ![]() ![]() ![]() |
hi all, so i k ow this is an old thread now but thinking of attempting this fix myself given all of the amazing advice and pictures however I am just wondering......if i take the car to LR dealer along with the bulletin... are they likely to do the fix as per the bulletin or will they tell me i need a complete new assembly and charge me the £1500 to do that. i.e are they obliged to do the fix as per the bulletin even though is not a recall? |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 157 ![]() ![]() ![]() |
So I finally got to the point where I was fed up of filling the tank to the click and the gauge only showing three quarters full. I’d managed to plan my journeys to use all the fuel and get the Rangie home (despite the gauge having gone straight from a quarter full to dead empty and “- - -“ showing as range). So, with an almost empty tank and this excellent guide I opened everything up, only to find the driver’s side has already had the crimps installed by a previous owner.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Got the same problem with the "bridge".How did you fix it and is it still holding? Thanks 2012 TDV8 Vogue SE 4.4 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
Ever since I've had my 5.0, when the fuel light comes on I only get 80 or so litres in the tank and recently it's started to annoy me as you think it's empty much quicker then it should be.
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 21 ![]() ![]() |
Evening all. I have been having this issue and working through the service bulletin to rectify the issue.
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 83 ![]() ![]() ![]() |
Jimmy86,
