Home > Maintenance & Mods (L405) > Brake hoses |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
I have not seen braided lines for the current L405, plenty for the classic and P38 models as I expect there are more people out there converting them for off road events. I would suggest you give HEL a call as I know they can do custom brake lines. I may also ask is there a particular reason you want braided on a road car, perhaps just a replacement of the existing rubber hoses would be good enough? 2021 L405 Vogue D300
13th May 2021 8:34am |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 285 |
I had them fitted to my D3 to replace the rubber ones which needed replacing every so often. Would like to do the same to the L405. More preventative maintenance than anything else.
13th May 2021 9:07am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I had a look around recently for some but couldn't find any unfortunately. If you come across some Ivan, please let us know because I'd also be interested in a full set as mine are due for renewal also.
13th May 2021 12:10pm |
