Home > Maintenance & Mods (L405) > Brake hoses
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Brake hoses
Does anyone know of a company that makes Braided Stainless Steel brake hoses for the L405 SDV8?
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #594093 13th May 2021 8:20am
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
I have not seen braided lines for the current L405, plenty for the classic and P38 models as I expect there are more people out there converting them for off road events. I would suggest you give HEL a call as I know they can do custom brake lines. I may also ask is there a particular reason you want braided on a road car, perhaps just a replacement of the existing rubber hoses would be good enough? 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #594095 13th May 2021 8:34am
IGP
I had them fitted to my D3 to replace the rubber ones which needed replacing every so often. Would like to do the same to the L405. More preventative maintenance than anything else.
Post #594103 13th May 2021 9:07am
knwatkins
I had a look around recently for some but couldn't find any unfortunately. If you come across some Ivan, please let us know because I'd also be interested in a full set as mine are due for renewal also.
As I understand it, whilst the rubber ones can bulge under pressure causing an imbalance when braking, the stainless braid prevents this. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #594133 13th May 2021 12:10pm
