Home > In Car Electronics (L322) > Dash cam suction
JohnW
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Dash cam suction
Morning peoples of the world.
I have used NextBase dash cams for a few years now but for some reason on my wife's car (Ford B-Max 2013) and my new RRTDV8 (2011) I cant get the dash cam to stay stuck on the back window, front is perfect. On my previous car (Freelander2 2007) it had no problem sticking front and back but on RR it lasts about 10 mins of driving then starts swinging across the back window.
Looks like I have to add some sort of adhesive but don't want to use something that will damage the suction cup or leave a mark on the rear window when its removed.
Do other people have this problem and if so, what do they use to keep the back dash cam in place?
Thanks in advance.
Almost 2 months in to my First FFRR and still massive grin when driving Smile
John[/b]
Post #593853 11th May 2021 8:32am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
One of the biggest issues is not making sure both sides are clean, clean, clean! Use a really good glass cleaner to clean the glass and the surface of the suction mount. Failing that, yes, some double sided tape may be the needed solution.
The dashcams I have in my cars uses suction for the front facing camera and double sided foam tape for the rear facing camera.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #594011 12th May 2021 3:17pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
The only time mine fall off either front or rear is during really hot weather, otherwise they stay in place for months Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #594061 12th May 2021 7:49pm
JohnW
On my Freelander 2 they stayed on the front and back for 3 years but as you say, in hot weather they can drop off. Have cleaned windows but suspect its something to do with ridges in the rear glass so may try double sided tape and see how that goes.
Post #594073 12th May 2021 10:18pm
Sleepy Jen
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
I have cut off the sucker and replaced it with automotive double sided tape, winner!!! Thumbs Up
All weathers and temperatures, it remains in place. Just avoid the heating element strips on the back window if you have them.
Post #594385 16th May 2021 1:55pm
JohnW
Have ordered some 3M stickers from Amazon that say they are for dashcams and other things. Hoping they will work.
Post #594389 16th May 2021 3:14pm
JohnW
Problem solved, about £4 from Amazon for 2 50mm 3M clear stickers, and now not dropped once in over a week.
Post #595786 30th May 2021 12:03am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
This works 100% for me.
https://www.youtube.com/watch?v=PNbrwV9Z21M 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #595818 30th May 2021 8:31am
