Home > Technical (L322) > Which air compressor do I need?
Jonnys19882
United Kingdom 2005 Range Rover Vogue Td6 Adriatic Blue
Evening all!
I have just purchased a 2005 td6 vogue and typically on the way home I got the “air suspension inactive” message. Dropped in to my local indi who plugged it into diagnostics and told me I need a new compressor, but after having a look on the net there seem to be a few different types! I was wondering if anyone knew the specific one that I needed?
Thanks in advance
Post #593913 11th May 2021 6:44pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
My now dead and probably decaying 2011 322 SC had the Hitachi compressor, with some odd bolt on differences to the Hitachi used on the Discoveries, such as bronze filters and so, but the pump was identical...
Was a 2 minute job removing the spare wheel and opening the compressor top housing in the boot to identify the hethen pump...
Not sure if yours is the Hitachi as well, but if you could open the housing and take a pic it would help..
Post #594000 12th May 2021 1:54pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Do a search on here. may just need the cone drilled to allow it to breathe, many examples of it being just that, good luck Thumbs Up
Post #594002 12th May 2021 1:56pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Check out my story? https://www.fullfatrr.com/forum/topic53796.html
Post #594012 12th May 2021 3:20pm
Jonnys19882
Thanks all.
I have now got a replacement compressor and a new battery on the way (the HDC light flashed on start up) hopefully these two will solve to issue. Now to fix the heavy steering. Another sensor I suspect!
Post #594013 12th May 2021 3:34pm
