Home > Technical (L322) > Recommendations for a 4.4V8 Diesel Jump start pack please> |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
I used to disconnect mine , might be sensible getting a cut off switch fitted. |
11th May 2021 6:04am |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 196 |
thanks
11th May 2021 4:11pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
How old is your battery? Have you checked it is the correct sized AGM? |
11th May 2021 6:39pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Starter is probably on the way out. |
11th May 2021 7:04pm |
I was watching for the recommendation of a good jump start pack.... just in case....
11th May 2021 7:49pm |
One of the bigger NOCO ones - GB50 or GB70. |
11th May 2021 8:02pm |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 |
I've also been watching.
11th May 2021 8:08pm |
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 |
NOCO GB150 - does a very good job! |
11th May 2021 8:30pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
I've had a NOCO GB70 for a few months now and it's been fantastic.
12th May 2021 7:25am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
GB70 here, but I am installing a dual battery system from Traxide:
12th May 2021 10:15am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
Ironically since I got my GB70 a few years ago I haven’t had a problem. I have helped a few other though - works a treat Geoff |
12th May 2021 1:41pm |
Thanks for the replies.
25th May 2021 9:02pm |
Ido t think the original was AGM. I will check the replacement |
26th May 2021 7:38pm |
You sure it’s the battery and not the starter motor?
26th May 2021 8:35pm |
