Home > Technical (L322) > TDV8 4.4 Air Compressor
paulwlincs
Hello , I notice that my suspension compressor starts up every time I start the engine , runs for a couple of minutes then goes off . The car doesn't drop overnight but I'm thinking there must be a leak somewhere ?
Am I concerned over nothing .
Cheers for any help 2011 tdv8 4.4 vogue Santorini black
Post #593311 5th May 2021 8:42pm
DrRob
Ignore and enjoy the car Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593334 6th May 2021 8:48am
BenRK
Mine does the exact same. Can he left for a week and its height doesn't change but will kick in most times it's turned on. I know on my disco 3 the air compressor was rotten and had loads of tiny pinholes and was losing pressure but I don't think it's the cause of it on the range.
Post #593340 6th May 2021 9:25am
paulwlincs
sounds like my ocd is kicking in again then Whistle 2011 tdv8 4.4 vogue Santorini black
Post #593347 6th May 2021 10:56am
Merchy
As to your OCD, join the club.......
My 15 year old Td6 is still on the original compressor and does the same sometimes, but suspension never drops, and the compressor never runs excessively so seems normal, as said in above posts, don't worry about that.
Enjoy the respite until the next fault arrives..... Rolling with laughter
Post #593348 6th May 2021 11:11am
mjdronfield
The compressor tops up an air tank I believe, not the air bags directly. The bags use the air tank, so if they need air the air tank drops pressure and the compressor comes on to top that up, so it may appear it does the bags directly if you are listening.
It’s normal for it to come on and off, but not stay on constantly.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #593352 6th May 2021 11:42am
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Having left mine on SORN for 5 months my compressor came on and I suspect the tank was nearly empty as I had a normal height only message on dash as i suspect the pump was overheating. Second time it was used no problem. It did the same last lockdown at the beginning of 2020. I intend to service the compressor soon just to be sure. I know you can look at tank manifold pressure as its measured so could do this a number of times after leaving car for a few days.
The tank does supply the bags when they need it but I think only when engine running. You can also disconnect pump as there's a valve that stops tank depressurising
Rog L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #593365 6th May 2021 2:29pm
Rog21
Having monitored the manifold pressure and compressor temperature with the car left for a few days the compressor only kicks in when I demanded a height change, looks like the manifold pressure isn't the tank pressure. Any thoughts?
Also the pump temperature rises to just over 100 deg C when moving from normal to offroad before it has refilled the tank. Is this normal and at what temperature does the overheat alarm get raised ?
Roger L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Post #593825 10th May 2021 8:30pm
