Home > Maintenance & Mods (L405) > Wife broke my Key
Mr Tee
Wife broke my Key
So SWMBO dropped my key, it's clearly broken something on the PCB as it no longer works. Called local dealer £675, includes coding though..... Holy mother of God, tell me that's a p!ss take...
Post #593226 5th May 2021 9:53am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Buy a new key off Ebay and get someone with an IID Tool Pro to program it for you.
Mikey is in Dundee and he may be able to help you.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #593228 5th May 2021 10:19am
Mr Tee
jeezo, i've got an IID tool in the car, looks like I can maybe DIY..
Post #593229 5th May 2021 10:29am
for a L405?
check that the battery hasnt been dislodged.. ... - .- -.
Post #593234 5th May 2021 10:50am
Mr Tee
aye Stan, tried that, fired a new one in too, nothing obvious tbh.
Post #593236 5th May 2021 10:52am
Kot
Make 2, while you are at it. Laughing 2018 SE SDV8 4.4 Byron Blue
Post #593241 5th May 2021 11:18am
andygts
IIDtool won't do anything unless he's very very lucky and got a non updated KVM (keyless Vehicle Module). The KVM modules had an update making them a one time write for key codes to help with security ie thieves turning up with a key and just programming a new key in seconds.
The dealer will be quoting for a new KVM aswell as a key, sounds similar to what I was quoted.
My replacement key cost about £200, the KVM had to be removed, the memory chip desoldered and put on a chip reader/writer to delete and add the key codes and then re solder it back into place. The lock the Land Rover put on the KVM is upstream of the memory so it's still possible.
You've just got find a good auto locksmith that has the right equipment. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #593269 5th May 2021 2:11pm
Chalky
Re: Wife broke my Key
Jesus, Mary and Joseph and the Wee Donkey, that's "I saw you coming!!" Censored All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #593279 5th May 2021 4:05pm
Mr Tee
Cheers lads . I would hope, in my naivety that since mine is an early one (2013) that the KVM might not have been updated.. found a cheap second hand remote on tinterwebs so happy to lose a few quid before deciding what to do. The parts guy did say to check if insurance covered it. Yes it does , but standard excess applies, I’d hoped it would be a reduced amount a la windscreen etc. my excess is higher than quoted, if needs be, I’ll shop around, should the eBay remote not work. Might see if the old man has a magnifying glass & a soldering iron first, can’t break the thing more...
Post #593326 6th May 2021 7:01am
Even with the early L405's it was a free upgrade/recall at the time. I remember taking mine in for the work maybe 2015 ?
You never know though & certainly worth a try
Post #593329 6th May 2021 7:43am
Mr Tee
Cheers Alistair, this is a new area to me . Can always claim it as a business expense I guess.. not like she's my accountant too..... Thumbs Up
Post #593331 6th May 2021 8:09am
