![]() | Home > In Car Electronics (L405) > Speaker 'crackle'. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1138 ![]() ![]() |
You weren't playing Cracklin Rosie were you???/ |
Broadoakboy Member Since: 23 Nov 2020 Location: Wiltshire Posts: 26 ![]() ![]() ![]() |
I have found the problem....the void under the passenger seat (where the amps are) is FULL of water! DAMN IT!!!!
Lots of threads about sunroof drains and door seals
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1155 ![]() ![]() ![]() |
Not sure about the L405, but another source of water ingress could be the air intake for the blower, if similar to an L322, these drains could be blocked and letting water enter the air intake. The water could easily travel under the carpet 'through' any insulation.
Hi all, an update.
The near side metal join between the rubber drain tube and the opening in the sunroof gutter was completely corroded/missing! The off side has been checked and is ok.
All fixed, car now dry but all electronics under the seat will need replacing. No bluetooth, no stereo, no satnav etc
elsterracer Member Since: 29 Nov 2022 Location: Heilbronn Posts: 15 ![]() ![]() ![]() |
Can anybody explain to me (or post a linnk) how to reach this "void under the passenger seat (where the amps are)"?
