Home > Maintenance & Mods (L322) > Another day another problem
Right,
On my way home from playing golf car starts making a horrible noise like its dragging something. Turns out to be the shield that sits behind the front disc's. its held (was) by 3 bolts into the hub carrier and the aluminum shield has corroded thus vibrating and making the horrible din. I've removed said part by cutting it to go over the hub carrier. does anyone know how the hell the new one will go on? i'm assuming its a cheap part and not needed but cant for the life of me see how it will fit over the axel ends to get to its home location! Any help?
Also in this afternoons DIY i've discovered my outer dust cover on the caliper piston is dead. does anyone know or have the part number to replace this? seals aren't leaking but i'm sure they will if i don't fix next week when i do the brakes.
Post #59293 7th Apr 2011 4:35pm
The hub need to be split to replace the rear covers, but not worth the hassle of doing that. I have new covers for mine and I will cut them and slip them into place then stitch a small weld over the cut to finish the job off.
You can buy caliper seals at LR, they comprise of inner and outer seal and bought as single side packs
Post #59295 7th Apr 2011 4:40pm
are the inner seals easy enough to replace? it was fronts by the way but will do the same and cut the guard and weld.
Post #59298 7th Apr 2011 4:44pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Had the same happen to my brake shields. Like has been said, just cut them to fit. I used penny(bodgit washers) to strenghten area around mounting holes.
Post #59300 7th Apr 2011 4:53pm
Is it the inner seal (the one that keeps the fluid in) or the outer dust seal?
Post #59301 7th Apr 2011 5:05pm
Outer dust seal. Thought if it came in a kit with inner and dust might do both if the inners were easy.
Post #59303 7th Apr 2011 5:47pm
You would have to bleed the brakes if you changed the inner seals. If the calipers aren't leaking or sticking just change the outer dust seals. Make sure that all the crud is cleaned off the retaining lip before fitting the new seal. piston has th be pressed fully home before the seal can be fitted
Post #59304 7th Apr 2011 5:52pm
Ok that sounds good. Will give them a good clean and re-fit the seal. What's best for cleaning the pistons? Do you have the part numbers for the seals and guards?
Post #59308 7th Apr 2011 6:44pm
The seals kit is part number SEE 000020
Clean the lip with a piece of fine emery cloth or sand paper or steel wool and make sure no dirt goes into the caliper bore
Post #59311 7th Apr 2011 6:55pm
is there a part number for the sheild thats toast? will get new ones ready for the new brakes.
Post #60414 14th Apr 2011 10:00pm
This should help Thumbs Up
Post #60494 15th Apr 2011 5:53pm
TOP MAN! Thumbs Up but £25 each side for a bit of crappy tinfoil! Think LR are taking the pi$$
Post #60643 16th Apr 2011 5:24pm
