Home > Maintenance & Mods (L322) > Another day another problem |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Right,
7th Apr 2011 4:35pm |
are the inner seals easy enough to replace? it was fronts by the way but will do the same and cut the guard and weld. |
7th Apr 2011 4:44pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Had the same happen to my brake shields. Like has been said, just cut them to fit. I used penny(bodgit washers) to strenghten area around mounting holes. |
7th Apr 2011 4:53pm |
Is it the inner seal (the one that keeps the fluid in) or the outer dust seal? |
7th Apr 2011 5:05pm |
Outer dust seal. Thought if it came in a kit with inner and dust might do both if the inners were easy. |
7th Apr 2011 5:47pm |
You would have to bleed the brakes if you changed the inner seals. If the calipers aren't leaking or sticking just change the outer dust seals. Make sure that all the crud is cleaned off the retaining lip before fitting the new seal. piston has th be pressed fully home before the seal can be fitted |
7th Apr 2011 5:52pm |
Ok that sounds good. Will give them a good clean and re-fit the seal. What's best for cleaning the pistons? Do you have the part numbers for the seals and guards? |
7th Apr 2011 6:44pm |
The seals kit is part number SEE 000020
7th Apr 2011 6:55pm |
is there a part number for the sheild thats toast? will get new ones ready for the new brakes. |
14th Apr 2011 10:00pm |
This should help
15th Apr 2011 5:53pm |
TOP MAN! but £25 each side for a bit of crappy tinfoil! Think LR are taking the pi$$ |
16th Apr 2011 5:24pm |
