Home > Off Topic > Tiger seal removal
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Tiger seal removal
Hi all
Need some advice please. Anyone know how you can remove this tiger seal below without damaging the paint work.
Cheers all
Post #592980 2nd May 2021 8:46pm
Hair drier and fine fishing line / dental floss? .
Post #592990 2nd May 2021 10:37pm
Bean19844
Tried the hair dryer as I've got a heat gun but it just melts yhe paint work as I found on the rear bumper
Post #592991 2nd May 2021 10:41pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Oh wow. That is some dodgy spoiler install 😬🤣 I really don’t like using that stuff for such installs.
Anyway, I would warm it up as well. Remove the spoiler. Then use tar remover and possibly one of those gum wheels on a rotary tool to get the remainder off.
It will be really hard to remove that without damage. And use 3M automotive double sided tape to put the spoiler back on.
Post #592992 2nd May 2021 10:57pm
Merchy
Cut the largest bits off with a scalpel, keep blade horizontal to bodywork. Then use silicone sealant remover, try the remover on paint first where it will not be seen. That and plastic tool, such as from a trim tool kit, as this should not scratch your pride and joy.
If you have to start the job all over again, apply the minimum sized bead of sealant required, then spray the whole area ( Including the sealant bead ) with a mix of water / soap, such as fairy liquid etc till it's soaking wet, then run you finger along the sealant, you will get a superb finish and the excess sealant will only stick to you finger. Let sealant go off and rinse with clean water, watched professional bathroom fitters do this, very simple, easy and effective.
Edit - Just posted this and read Blackdog's comment as to the spoiler fitting, perhaps the installer was reading the instructions by Braille Rolling with laughter Looks like the stuff was applied with a trowel. Shocked
Post #592994 2nd May 2021 10:59pm
Bl4ckD0g
Yes looks like the guys who did the roofline on our house. Cut the boards short and just fill it up. They never saw their money Wink
Post #592998 2nd May 2021 11:11pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Warm the area, nylon fishing line to slice through the silicone. Once removed, screwfix do a half decent silicone remover that doesnt seem to attack paintwork but do test it first or a toffee wheel in a drill used with care.
Good luck BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #593010 3rd May 2021 4:00am
Petrol will bring it off but it will be hard work.
Post #593026 3rd May 2021 9:49am
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Cellulose thinners is excellent at removing it with care. 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #593063 3rd May 2021 6:04pm
Bean19844
Cheers all. I'll give some of them a try later this week. I've ordered a toffee wheel and going to stop into halfrauds n get some tar removal etc
Truth is it was me that fitted it but I got distracted and completely forgot about it. Ended up having too put the whole car on hold for a few months courtesy of the shebeast so it was nicknamed the dustbru
Sure the following pics explain the nickname 🙄
Post #593070 3rd May 2021 8:14pm
MonkeyMan
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
How much dust!!! Do you live in a desert??
Also, that reminds me of my kids bedrooms.
Post #593071 3rd May 2021 8:17pm
