![]() | Home > Maintenance & Mods (L322) > Quick opinion - do these have plenty of life left? |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 ![]() ![]() |
Thanks.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Considering the costs involved, once I have brakes apart, unless the 'old pads in use' are quite new, then I always chuck new ones in, saves time and gives you more time for all the other jobs, yours look like they have quite a bit of life left on them. As in one of the above posts, give them a damn good clean and they should be OK. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
As above, if you have got it apart you might as well replace the pads, but that said, those have pretty much all the friction material left on them, so a good clean up and a decent amount of anti squeal then they should be fine.👍🏻
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Plenty of life in them, especially if you only do 5k.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
They are only 20% used imo, keep the new ones for later |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Why would you only change one caliper? And only one slider? Only ever change brake components in pairs! |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I was wondering that as well |
