Home > Maintenance & Mods (L322) > Quick opinion - do these have plenty of life left? |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 |
Hi,
1st May 2021 3:03pm |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 |
Thanks.
1st May 2021 3:09pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Considering the costs involved, once I have brakes apart, unless the 'old pads in use' are quite new, then I always chuck new ones in, saves time and gives you more time for all the other jobs, yours look like they have quite a bit of life left on them. As in one of the above posts, give them a damn good clean and they should be OK. |
1st May 2021 3:38pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8507 |
As above, if you have got it apart you might as well replace the pads, but that said, those have pretty much all the friction material left on them, so a good clean up and a decent amount of anti squeal then they should be fine.👍🏻
1st May 2021 4:21pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Plenty of life in them, especially if you only do 5k.
1st May 2021 7:50pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
They are only 20% used imo, keep the new ones for later |
1st May 2021 9:40pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Why would you only change one caliper? And only one slider? Only ever change brake components in pairs! |
1st May 2021 11:00pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I was wondering that as well
2nd May 2021 6:15am |
