Home > Technical (L322) > Air Compressor Dryer dismantel
harleyman
Spain
Hi,
Hope you`re doing well
I woud like to change filters and the desiccant material that goes inside the air compressor dryer and I wuld like to know if I have to take all into bits or I can take off the dryer alone?
I hope I´ve explained my shelf
Thank you
This is my compressor
 2012 Range Rover 4.4 tdv8 Autobiography
Post #592403 26th Apr 2021 8:28am
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
i will be interested as i am looking at mine to give it a service . it is not giving any problems and i suppose i have toooo much time on my hands but i think it is worth doing .
Post #592411 26th Apr 2021 9:40am
rjff
The workshop manual (look in the Wiki) states the compressor is removed for the dessicant renwal. The info on the intake filter is also in the WM.
follow
wiki/2010-2012 Workshop Manual\Suspension\Vehicle Dynamic Air Suspension/filter AND drier.
HTH Cheers
Richard
Gap IIDBT
Post #592484 26th Apr 2021 9:16pm
Merchy
As the compressor has to end up on the work bench, it may be a good idea to overhaul the compressor at the same time - Depending upon how old the car is, compressor / system performance etc. Saves you doing the job twice, and it is not expensive to do.
Post #592493 26th Apr 2021 10:17pm
harleyman
Spain
Thank you all
I will check the wiki and see If I can manage to do the job myself
And good point to renew the compressor as it is going to be out. I will try to find a shop in Spain that could do the job 2012 Range Rover 4.4 tdv8 Autobiography
Post #592565 28th Apr 2021 6:06am
