Home > Maintenance & Mods (L405) > Window tint question -
HDFB110
United Kingdom 2019 Range Rover Vogue SDV6 Santorini Black
Issue is with window tint 'colours' -
Car is stock - came with factory window tint -
Front windows should be clear (or very minimal tint, not exactly sure) - these look OK
The rear passenger (door & quarter pane) & rear window should all be the same (not too sure the %age tint?)
Maybe not the best pictures but I seem to have 4 different levels of tint?
Clear front, then brown (ish), then red (ish) then dark gery?
Is this normal - I know and realise in sunlight the tint might look different but surly they should all be the same?
Could it be that some of the tints were done in the facotry & others by the dealer?
Both sides are the same?
Any comments or thoughts welcome !!!!
Post #592339 25th Apr 2021 3:02pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
That looks very odd - factory tints are obviously all the same colour.
Post #592347 25th Apr 2021 4:51pm
That’s not quite right there.
The door and 1/4 should match the boot glass. Not sure what is going on is it the same the other side? There is nothing that can't be fixed with a hammer😜😜
Post #592354 25th Apr 2021 5:42pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Speaking from experience only thing I can think of is its possible the rear windows might have been smashed at some point prior to ownership and had the lm replaced but used a different brand of tint with different glue etc that's reacted in the sun over time. I had this on a previous car that had tinted windows as standard. The dealer smashed the window and got it replaced at no charge but after a few years I noticed the difference
Post #592356 25th Apr 2021 6:15pm
HDFB110
Hum - yes my thoughts were that factory tints should all look the same
The rear window looks ‘right’ and matches the rear door lid glass
Yes both sides are the same
Looks like it’s a question for the dealer - kind of worrying if the glass has been broken !!
Post #592358 25th Apr 2021 6:55pm
Vogue
The std LR tint is quite subtle - and can still be seen through from outside quite easily. Some owners put an additional tint on top of the factory to prevent views into the vehicle - this can result in the effect that you have on yours. I’d check the vehicle for an additional tint film on top of the factory tint.
I carry shotguns, dogs and expensive hunting gear in my RR and want to avoid people seeing what is inside - I have done just this ^ but used permanent car shades on top of the tint - it’s impossible to see in, but I can still see out and it gives an extra layer of security 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #592370 25th Apr 2021 9:01pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
The factory glass does have this brownish tint on the rear passenger windows from factory.
Something to do with the heat reflecting anti UV glass with built in tint in the glass. For the passengers.
The front windows are a lighter color. But not the brownish color of the rear windows at certain angles or lighting the back windows look different.
This might be because the back passengers are often being driven by their drivers , or carrying their special little ones to school,
so they get a better grade of anti UV light and heat reflecting tint in their windows.
Post #592406 26th Apr 2021 10:11am
TJH1985
I would say our L405 has the redish hue in certain lights, buts it’s on both the rear door windows and the rear quarter pane. I always through it was just the solar or laminated glass or toughened (not sure what it has). Looks normal dark black most of the time, but certain lights it’s very odd looking.
I will try and get a picture later Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #592413 26th Apr 2021 10:44am
5.0
Mine is like this when bright sunlight shines right on it. The tint is the same with the loadspace window but the glass is different. I think the rear door glass is laminated or solar reflective whereas the loadspace isn't.
Post #592445 26th Apr 2021 4:01pm
Happened to notice a pinkish tinge to ours earlier but nothing like the OPs pic. Possibly in a different light..... There is nothing that can't be fixed with a hammer😜😜
Post #592616 28th Apr 2021 8:49pm
All L405's (& later double glazed L322's) are the same as the OP's!!! The inconsistency comes from the rear doors having laminated double glazed windows, the rear quarter window (side boot glass) is just single layer safety glass so the tint is stable... Unfortunately there is nowt you can do about it sir! Whistle Thumbs Up
Post #592632 28th Apr 2021 11:28pm
