Home > Technical (L322) > Manufacturer recs new bolts? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I’m not sure about all of them, but i know some bolts are made to stretch when fitted correctly and need to be replaced once undone. I’m no expert here, so don’t know what they are called.
23rd Apr 2021 8:19pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
imho many are sold with a thread lock compound already on the bolt, so reusing is fine just use an appropriate thread lock. Obviously dont do this with stretch bolts and make up your own mind about some high stress bolts. Personally I normally reuse all bolts except very high stress bolts on some parts of the suspension.
23rd Apr 2021 8:50pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
To add to the above comments, 'Stretch bolts' I have encountered have always been for the engine head(s), due to the composition of the metal they stretch to a set measurement at a pre-prescribed torque. ( Or turning angle )Once used they will basically not stretch to the correct settings again, due to the loss of elasticity (ductility )hence they are single use only. Generally thread lock is not used with stretch bolts unless the makers specify it's use.
23rd Apr 2021 9:42pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Considering they cost less than a cup of coffee I don’t even think twice and like putting new bolts on my cars when replacing parts. |
23rd Apr 2021 11:07pm |
