Home > Technical (L322) > Air suspension inactive
Pazuzu
Got this message yesterday and I haven't been able to clear it Sad
We went down to the coast for the day and I'd used the suspension a couple of times - access height and offroad height.
Parked in an underground car park for a couple of hours then when we came back wifey was feeding number one son and I think I clicked the dial round to put the suspension back up to normal height while the ignition was on but the engine not started.
Didn't notice anything there and then but after we'd left the car park the message was up.
Tried switching on and off
Tried full left lock and full right lock
Had a look at the compressor when we got home and it all looks fine
Disconnected the battery for 10 minutes but message remained although compressor whirred away for a few minutes - presumably pressurising the system.
Cleared all fault codes but still no joy.
I'm thinking it might be a sensor or possibly it's registered overheating as the compressor was quite hot when we got home.
Is there anything else worth a try before I pop it in the garage?
Cheers!
Phil
Post #5922 1st Jun 2009 12:36pm
Landrovered
United States 2003 Range Rover HSE 4.4 V8 Giverny Green
My guess is one of your front air struts has a leak. Not bad enough for a hard fault but enough to throw the code. In my experience it leaks when on the highway and access settings and holds air when the bladder is extended in offroad height. It is a common problem from what I am told.
To check for a leak, jack up your rear wheel on one side and then the other. If the front is leaking you will be able to hear it when the front strut is compressed, the cracks in the bladder will leak.
See my "air strut post mortem" thread for a picture. 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5926 1st Jun 2009 1:52pm
Larry
England 2006 Range Rover SE Td6 Java Black
You could try spraying This on the air bag and looking for bubbles when following the previous advice (just don't get your head between the tyre and the wheel arch - might not be the best idea with a potentialy leaking air bag! Very Happy ). Great stuff. Good for finding punctures too!
Post #5928 1st Jun 2009 2:15pm
Pazuzu
Not a leak as far as I can tell but I'm popping in to see AHL on the way home and he's going to pop it on his autologic and do the software update that recalibrates the overheat settings and see what fault codes it throws.
Cheers,
Phil
Post #5929 1st Jun 2009 2:47pm
Landrovered
Let us know what the outcome is.
I have a fiver on a leaky air bag, any takers? 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5931 1st Jun 2009 2:52pm
Pazuzu
$5 or 5 of the Queen's £s
Phil Smile
Post #5932 1st Jun 2009 2:54pm
Landrovered
We could compromise and do 5 euros! 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5934 1st Jun 2009 2:58pm
Larry
It's all the same these days Very Happy Very Happy (ie. bloody worthless)
Post #5936 1st Jun 2009 3:03pm
Pazuzu
Compressor temperature fault.
Angus updated the software and cleared the fault and so far so good Smile
Cheers,
Phil
Post #5940 1st Jun 2009 6:52pm
Landrovered
Glad you got it fixed. 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5941 1st Jun 2009 7:05pm
