Home > Technical (L322) > TDV8 Injector/Leak off Pipe Diesel Leak. |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 |
Evening,
19th Jan 2017 6:32pm |
Answered it myself
20th Jan 2017 4:21pm |
Kidsathart Member Since: 02 Nov 2020 Location: Essex Posts: 2 |
Hi just bought this amazing car
2nd Nov 2020 7:21pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
It should come out if the plenum chamber is out (the box that holds the cabin filter)
16th Nov 2020 7:42pm |
Thanks for your reply, I had removed the filter chamber and aircon pipe was just jamming it, it became a case of very carefully springing the pipe and it finally came out.
16th Nov 2020 7:56pm |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Would you happen to have number for o rings or size spec please. |
19th Apr 2021 11:12am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
LR019118 is what we used, I would double check it though as always I still have some I think, I will check the part number on the bags.
19th Apr 2021 12:37pm |
Brilliant many thanks. Getting ready to remove manifold. |
19th Apr 2021 2:14pm |
OK, update i have removed all bolts from plastic manifold on drivers side removed injectors but seems to be a clamp hooked over stud. just when i though acces was bad enough on injectors etc. Does this come off? |
25th Apr 2021 12:37pm |
