Home > Technical (L322) > TDV8 Injector/Leak off Pipe Diesel Leak.
lazylabs
Evening,
Discovered a leak around drivers side injectors. When idling can see diesel dripping down.
Assuming it's either leak off pipe or a leaking injector.
No errors on dash. Haven't read codes yet but presume something would show on dash? Car drives fine.
So wanting to remove the driver side fuel line shield. 7 nuts I believe.
Any advice? Anything else that needs to come off to allow it to be released?
TIA. Current Family:
2012 FFRR 4.4 TDV8 Westminster
2013 Jaguar XFs 3.0d Sportbrake
2008 FFRR 3.6 TDV8 VSE (Gone)
2008 Ford Mondeo mk4 2.2tdci (Gone)
2006 S Class 320 CDI (Gone)
1998 P38a 4.6 VSE Oxford Blue 98k (Gone)
Vx Vectra C Estate 1.9cdti 150 (with a few twists) (Gone)
Other LR's in Family (2019 4.4 TDV8 AB)
Post #423823 19th Jan 2017 6:32pm
lazylabs
Answered it myself Very Happy Very Happy
Just the Plenum Chamber needs removing if anyone is interested. This gave me the required access to remove all 7 nuts from the Drivers side Fuel Line Shield and remove it.
Leak off pipe o ring replaced. no more leaks...
Cool Cool Current Family:
Post #423987 20th Jan 2017 4:21pm
TJH1985
Just replaced our’s - same thing diesel leak when idleing and dripping from underneath - coming from number 8 in our case.
Doesn’t matter how many times I have had the shields off I loath putting the 7 nuts back on Censored
Post #495591 14th Nov 2018 9:07pm
Kidsathart
United Kingdom 2008 Range Rover SE TDV8 Barolo Black
Hi just bought this amazing car
Project Karn TDV8 Vogue but has this leak.
So after some working I managed (and not too sure how) undid all 7 nuts now had almost got it out but would not come past the Aircon pipes.
I had removed the bracket to get air scoop off but am worried about how much to pull on those pipes.
Any tips please.
Post #571632 2nd Nov 2020 7:21pm
kbald
It should come out if the plenum chamber is out (the box that holds the cabin filter)
The air com pipes have a bit of movement but it's a case of wiggling and eventually it will come out. No skill to it just perseverance and luck? Current 2007 TDV8 Vogue Buckingham Blue
Post #573048 16th Nov 2020 7:42pm
Kidsathart
Thanks for your reply, I had removed the filter chamber and aircon pipe was just jamming it, it became a case of very carefully springing the pipe and it finally came out.
I replaced the leaking seal on the one near to front and then the second, after that I just can't get my hands on 3 & 4 and as not leaking decided if it ain't broke don't fix it.
One thing may help others here.
The R clips can be placed in either direction, the engine was untouched as out of factory and all 4 R clips on that side are pushed from rear. It wasveasier to push them in front to back.
NOw hands Up I LOST ONE SOMEWHERE it just pinned out and was gon.
As a tip an elastic band over the head of clip and a piece of cotton tied to the band easy to remove once R clip is in place but its easy to recover if dropped while fitting in such a tight space.
Post #573052 16th Nov 2020 7:56pm
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Injector o rings
Would you happen to have number for o rings or size spec please.
Post #591709 19th Apr 2021 11:12am
TJH1985
LR019118 is what we used, I would double check it though as always Very Happy I still have some I think, I will check the part number on the bags.
We got them from the local Main Dealer for £1.50 each which is expensive but not worth the hassle otherwise. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #591717 19th Apr 2021 12:37pm
Landmark
Brilliant many thanks. Getting ready to remove manifold.
Post #591725 19th Apr 2021 2:14pm
Landmark
MANIFOLD REMOVAL
OK, update i have removed all bolts from plastic manifold on drivers side removed injectors but seems to be a clamp hooked over stud. just when i though acces was bad enough on injectors etc. Does this come off?
Post #592335 25th Apr 2021 12:37pm
