Home > Technical (L322) > TD6 fuel injectors iid tool live values
ianr63
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
TD6 has become a poor starter
iiD tool shows a few faults
low side fuel pressure (fuel filter)
the faults i am concerned with is Fuel Comp on the cylinders
Cyl 1 = 1
Cyl 2 = 1
Cyl 3 = 654
Cyl 4 = 655
Cyl 5 = 655
Cyl 6 = 655
Low pressure pump = 406.8 kpa
Fuel pressure @ idle = 31744.0 kpa
Fuel pressure @ 1500 rpm = 59392.0 kpa
Pressure regulating valve 0.3
Looks like service exchange injectors Big Cry
Post #591663 18th Apr 2021 9:16pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I have a couple of TD6s. One works fine. The other has fuel issues.Both have pressure figures very similar to yours.
The fuel compensation variance you have is common. Both mine have two in near 0 and four in the mid-600s.
As far as I can tell it doesn't indicate a problem, or not one anyone has been able to explain to me.
Probably best to look elsewhere, perhaps describe your symptoms and see what people suggest?
Post #591670 18th Apr 2021 10:10pm
ianr63
Thank you Mike
A new battery is required as the old one is now 2 years old, this will help with the cranking speed, i will change the fuel filter as well, easy stuff first.
i have done a leak off test 6 months ago, maybe time for another.
Car appears to run & drive fine, i wasn't sure on the fuel comp readings and if this is a major point for poor starting.
Post #591674 18th Apr 2021 10:54pm
Mike Edwards
One thing that I have found with my TD6 with the known fuel issue is that, whilst it still labours to start, it does start much better now after a new battery and a clean MAF. The MAF wasn't particularly dirty so the improvement could have come from cleaning up the electrical connector as much as cleaning the MAF itself.
Post #591675 18th Apr 2021 11:06pm
"Looks like service exchange injectors"
fortunately 1 & 2, easier to get at and get out Wink .
Post #591677 18th Apr 2021 11:32pm
stuart_2006
So out of interest, what actually are the fuel compensation figures? Is the ECU able to see how much of a 'bang' each ignition stroke of each cylinder produces (how?), and adjusts the injector timings to give even 'bangs'?
Post #591678 18th Apr 2021 11:44pm
