Home > My Range Rover > Well, I've done it!
Page 5 of 7 <1234567>
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
RRDunc wrote:
I've got fed up with the cubby box lid crashing down on my fingers so I've bought a genuine LR replacement damper for it.
Dunc.
You mean to say they're not supposed to come crashing down? Laughing 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #587519 15th Mar 2021 10:03am
PeteT80
Got mine from here, genuine LR part as well. https://www.ebay.co.uk/itm/224334610331
Post #587523 15th Mar 2021 10:17am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Thanks, Pete.
Just ordered another one for the upper lid.
Cheers,
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #587567 15th Mar 2021 3:03pm
RRDunc
The second cubby box damper arrived this morning and has now been fitted to the top lid. A bit of a trial to fit because there's sod-all information out there on how to do it.
So....
You'll need T15, T20 and two T30 Torx screwdrivers (ideally, 2 T30 sockets on ratchets, a T15 and a T20 screwdriver)
Open the top lid and undo the 7 T15 Torx screws holding the upholstered top in place.
This will now come off but it's tethered by the top of the damper.
Reach in with a small screwdriver or long-nosed pliers and remove the circlip then push the clevis pin out (I used the pliers on my Leatherman Wave).
Move the passenger seat forward so that you can get at the cubby box hinge.
Using the T30 ratchets undo the passenger side end of the hinge and prise the silver trim cover off
Using the T20 screwdriver undo the bolt holding the bottom of the damper in place.
Reassemby is the reverse of disassembly (to quote a famous car maintenance publication).
I'd be tempted to do the top of the damper first otherwise you're working with a restricted amount of room to get the clevis pin and circlip back in (ask me how I know! Rolling Eyes ) and you might want to grow a third arm to hold the lid in the right place while you get the lower damper bolt back in. Alternatively, do what I did and get someone to help you!
Good luck.
Post #587787 17th Mar 2021 5:27pm
RRDunc
The dechroming of my car is, I think, complete.
Post #587895 18th Mar 2021 3:45pm
RRDunc
Decided that I didn't like the white side repeaters.
Post #588955 25th Mar 2021 9:03pm
RRDunc
Looks much better after a wash. If you're in the Midlands I highly recommend LCW Mobile car care. Alex is a really nice bloke and does a cracking job.
Since I took these photos I've taken the sidesteps and front mudflaps off.
Post #589376 28th Mar 2021 4:19pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Looking great Smile
Post #589377 28th Mar 2021 4:27pm
RRDunc
Mudflaps on!
Post #589486 29th Mar 2021 7:38pm
RRDunc
Direct4x4 Raptor sidesteps on.
Post #589599 30th Mar 2021 9:21pm
DaleL322
Looks great Thumbs Up 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #589663 31st Mar 2021 1:10pm
RRDunc
Replaced the DAB module with a later Jag DAB+ one.
More channels available now.
Post #591621 18th Apr 2021 5:18pm
DaleL322
The DAB is something I wished worked better on mine I must admit, easy enough job to do? 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #591628 18th Apr 2021 6:09pm
RRDunc
It's reasonably straightforward, just fiddly.
Took about an hour, all told. Needed an adaptor to convert from two pin to four pin power connector, part number LR032814.
Post #591642 18th Apr 2021 6:39pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Looking good dunc, the wind deflectors set it off a treat. I never seen them ones before that go to the rear boot window, think they set the cars off brilliant. Chefkenmore got them on his and sent me a link to buy them, so i did and fitted them last week. You're not that far from me, I'll probably see you around sometime.
With mine fitted.
Post #591655 18th Apr 2021 7:53pm
