![]() | Home > Maintenance & Mods (L322) > Tdv8 3.6 inlet manifold |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
You can spray some soapy water on it and watch with the engine running for bubbles. Diagnosed mine doing this and was quite easy to see but you couldn't tell it was split once off. The other way would be a smoke test Current 2007 TDV8 Vogue Buckingham Blue |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3226 ![]() ![]() ![]() |
It’ll need to be a high pressure smoke test. When my 2011 4.4 tdv8’s pax inlet manifold went, it was such a hairline crack that a low pressure smoke test didn’t find it.
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Thanks, just need copper washer number now. I appreciate I could check when there out but wanted to gather all parts first. So far:
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 761 ![]() ![]() |
You might want to think about fitting a new manifold while you're at it. It is a big job to remove the manifold and even if yours isn't cracked now there's a very good chance that it will be shortly. |
I've been considering and now there are aftermarket options I did consider but then I thought no if I do it I would have to use good quality oem or genuine and the price started to get silly. I think genuine is about £300 a side, Chinese is £60 a side and after market from UK is about 250 a pair. Probably regret but looking for a positive at least I'll know how to do it next time. Lol |
