![]() | Home > Maintenance & Mods (L322) > Problem dismantling air suspension leg to fit new air bag |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
Old style -14mm allen key and add length with a bar / piece of pipe onto allen key, apply force and then give it sharp bloody hard blow with a lump hammer to break the tension. Just make sure the recess is spotless to stop the allen key slipping out. |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Thanks.
As you have the 1/2 inch drive 14mm allen, use that on a 1/2 inch drive breaker bar,500 or 600mm (Quite cheap) then use said lump hammer. Screwfix / toolstation 600mm B/Bar for £20
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Good thread here: https://www.fullfatrr.com/forum/topic47064-15.html Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Land Rover refer to it a an isolator or damper fitted to vehicles with High Performance Brakes. Helps with resonance under braking. |
Thanks. I will see how the car handles before deciding whether or not to buy some replacements.
I tried the brute force method as well, I have a impact gun that takes a lorry wheel nut off without a complaint and happily undid the crankshaft bolt on my old TD5.. but wouldn’t budge this, researched the loctite in the LR manual and realised to release it needed heat. Heated it up with some shields to protect everything else and it just spun off by hand |
They are around £120 each new and very difficult to find pre owned. |
I've been describing this device as made of aluminium. It's not. It is most definitely steel.
