![]() | Home > Maintenance & Mods (L322) > Problem dismantling air suspension leg to fit new air bag |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1232 ![]() ![]() ![]() |
Old style -14mm allen key and add length with a bar / piece of pipe onto allen key, apply force and then give it sharp bloody hard blow with a lump hammer to break the tension. Just make sure the recess is spotless to stop the allen key slipping out. |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Thanks.
I don't have a 14mm allen key - just a 1/2" socket male allen, but I will try that with a T-bar. |
As you have the 1/2 inch drive 14mm allen, use that on a 1/2 inch drive breaker bar,500 or 600mm (Quite cheap) then use said lump hammer. Screwfix / toolstation 600mm B/Bar for £20
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Good thread here: https://www.fullfatrr.com/forum/topic47064-15.html Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Thanks for this link, but it came just a bit too late. I got the blighter off in the end, but not without destroying it. I tried a very powerful windy gun with no effect. Then a tool designed to loosen crankshaft pulley bolts, again with no effect. I did consider that it might be loctited in place but, with a male thread, I discounted it because of the risk of causing the aluminium to expand and tighten the thread even more. In the end, I cut it off with an angle grinder. Being uncertain how it was made, I went at it in three cuts - as can be seen from the pics. The final cut did take about 2mm off the steel cup washer that is threaded internally, but this does not seem to be an issue. As I was close to completing the final cut, enough heat must have been generated to release whatever loctite had been used - and it spun off easily. So what is this component and what purpose does it serve ? It is described in the Arnott installation manual as a "top chuck" as fitted to 2006-2009 supercharged models. Mine is a humble 2007 TDV8 with the 3.6 engine. It has been missing from the top of the other strut for the three years I have owned it, so is it really necessary ? |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Land Rover refer to it a an isolator or damper fitted to vehicles with High Performance Brakes. Helps with resonance under braking. |
Thanks. I will see how the car handles before deciding whether or not to buy some replacements.
I tried the brute force method as well, I have a impact gun that takes a lorry wheel nut off without a complaint and happily undid the crankshaft bolt on my old TD5.. but wouldn’t budge this, researched the loctite in the LR manual and realised to release it needed heat. Heated it up with some shields to protect everything else and it just spun off by hand |
They are around £120 each new and very difficult to find pre owned. |
I've been describing this device as made of aluminium. It's not. It is most definitely steel.
