Home > Technical (L322) > caliper to hub retaining bolt torque
Dave Lowe
United Kingdom 2006 Range Rover Autobiography TDV8 Zambezi Silver
Hi I am changing the discs on a brembro brake l322 and have been looking for the torque setting for the caliper to hub bolts and found loads of different setting.
So was wondering if anyone could help with the correct torque please??
Thanks Dave
Post #591515 17th Apr 2021 11:48am
welcome to the forum Dave..
have a look in the WM...links are in our wiki.. ... - .- -.
Post #591519 17th Apr 2021 12:18pm
DrRob
Defo in the Workshop manual as I'm about to do this myself Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591521 17th Apr 2021 12:25pm
Dave Lowe
Ok Ta found it now, its 2 stage 48ftlb and then 90deg, I thought it was a bit loose.
Post #591525 17th Apr 2021 1:31pm
Dave Lowe
On the WIKI vidio it states 48ftlb but misses out the further 90deg turn, that was where I was getting confused.
Thanks All
Post #591527 17th Apr 2021 1:36pm
Just be careful on the 3.6, they changed the design for 4.4 and the bolts go through the calliper, on the 3.6 the threads are in the calliper.....not ideal to put a steel bolt into an ally calliper at torque, so bear that in mind when torquing it up, you do t want to strip the thread in the calliper. Make sure you wind the bolts in by hand so as not to cross thread them..... ask me how I know Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #591561 17th Apr 2021 8:20pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
@drrob sure yours is 203ftlb not 48ftlb though.
According to the WM for high performance brakes fitted to tdv8
 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591563 17th Apr 2021 8:52pm
Dave Lowe
oh dear that has stirred up a nets of stingy things, so I think as a relatively new guy to fatties you will understand
my confusion. In the manual on the wiki link it states 48 +90 deg I see other vids for just 48 and some for less and then others 125 and now 200+, now I have some knowledge of mechanics after joining the CEGB in 1967 and I am sure that 200+ is not correct for an ally thread on a bolt that size.
LOL why do JLR use so many variations, must be a cost driven motor company.
Dave Rolling with laughter
Post #591564 17th Apr 2021 9:34pm
DrRob
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591575 18th Apr 2021 6:51am
RJH
Are those torque settings for the rear?
Looking at toruqes they list 48lbft + 90 for the rear carrier to hub., not the caliper to carrier bolts. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591577 18th Apr 2021 7:19am
Dave Lowe
This from the 06 -10 manual
Front Disc Brake -
Item Specification
Disc type Ventilated
Disc diameter:
Vehicles without Brembo brakes 340 mm (13.5 in)
Vehicles with Brembo brakes 360 mm (14.1 in)
Disc thickness:
New 30.0 mm (1.18 in)
Service limit 27.0 mm (1.063 in), unless otherwise specified on the disc
Maximum disc run-out - disc installed 0.05 mm (0.002 in)
Vehicles without Brembo brakes:
Caliper type Sliding pin, twin piston
Piston diameter 48.0 mm (1.9 in)
Pad minimum thickness 3.0 mm (0.12 in)
Vehicles with Brembo brakes:
Caliper type Fixed, opposing four piston
Piston diameter 46 mm (1.8 in)
Brake pad wear warning lead:
Location Front left hand brake pad
Activates at 75% of pad life utilised
Torque Specifications Vehicles without Brembo Brakes
Description Nm lb-ft
Brake caliper bleed screw 14 10
Brake disc retaining bolt 16 12
* Brake caliper anchor plate to hub bolts:
Stage 1 65 48
Stage 2 Further 90° Further 90°
Brake caliper housing to anchor plate bolts 35 26
Brake hose union 32 24
* New bolts must be installed
Torque Specifications Vehicles with Brembo Brakes
Brake caliper bleed screw 19 14
* Brake caliper retaining bolts:
Stage 1 65 48
Post #591581 18th Apr 2021 8:29am
Just had a look at my copy of Rave.
For 4.2 S/C and 3.6tdv8 with high performance brakes;
Calliper fixing bolts torque to 48lbft +90deg. There is no carrier for brembos they bolt straight to the mounting points on the hub. Thumbs Up
For 4.4tdv8 L322 and 5.0 SC it seems to be 275NM or 203lbft.... as said above the 4.4 can take a higher torque as the callipers fix differently!
For L405 5.0S/c and 4.4 tdv8 with high performance brakes:
Front calliper fixing bolts are torqued to 133NM +60deg. There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 18th Apr 2021 8:58am. Edited 1 time in total
Post #591585 18th Apr 2021 8:42am
Kot
Is that with the bolt dry or wet Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #591586 18th Apr 2021 8:44am
Dave Lowe
I do wish JLR would Standardise! You need a degree in Manual reading just to find the right page, never mind the data.
Wet or dry, greased or de-greased that is a question, whether it is nobler in the mind to suffer the slings and arrows of Ft/lb or rotational torque that is the question. Big Cry
Post #591589 18th Apr 2021 8:55am
No grease! Supposed to use new bolts as well......
So the Dave OP is 48Lbft+90deg on his 3.6tdv8
DrRob is 275NM/203lbft on his 4.4tdv8 There is nothing that can't be fixed with a hammer😜😜
Post #591590 18th Apr 2021 8:59am
