Home > Technical (L322) > Tdv8 L322 2012 no crank, no power to starter solenoid
GraemeS
Australia
Providing power to the starter is the same as directly to the battery so shouldn't cause any problems.
I have no knowledge of the SDD system.
Post #591286 15th Apr 2021 11:47am
afyy27
Kenya 2012 Range Rover Vogue TDV8 Giverny Green
Someone suggested I connect the battery with a jumper cable with another car and try to start it from the ignition switch. As crazy as it sounds the car starts but I have to continously need to be pressing the start button. If I leave it then car stalls by itself. Can someone please give me a diagram for all the fuses in the car. I think there is a fuse or relay which is blown.
Post #591368 15th Apr 2021 10:43pm
GraemeS
Australia
Here is the MY11-12 central junction box wiring diagram which may not be the same as your vehicle due to your vehicle having the earlier engine which uses a very different PCM.
A faulty start/stop switch could possibly cause what you're experiencing.
https://www.fullfatrr.com/gallery/albums/u...0box~1.pdf
Post #591398 16th Apr 2021 10:55am
SilverSpanner
Scotland 2012 Range Rover SE TDV8 Stornoway Grey
I had a bit of bother with my 2012 FFRR Westminster. I had no brakes (intentionally) and it allowe the ignition on but not crank. After bleeding the brakes it was fine. They need to see hydraulic pressure in the ABS system.
You said the brakes were faulty and I wondered if it might be a similar problem. 2012, FFRR Westminster TDV8 - Orkney Grey
2003, FFRR Vogue TD6 - Zambezi Silver
IIDBT
Post #592063 21st Apr 2021 11:49pm
afyy27
Thanks for the input. I have ordered another ignition button, meanwhile I'll try to bleed the brakes again. Did you use software to bleed the abs system or just manual. I had tried bleeding the air before but there is no sufficent Fluid pressure pumping out of the brake lines. Oh well I'll try to bleed again. Thank you once again.
Post #592065 21st Apr 2021 11:56pm
tommartin
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Did you ever get anywhere with this? I have exactly the same problem at the moment so would be very interested to know.
Thanks,
Tom
Post #665640 1st Jun 2023 4:54pm
tommartin
To further my post, a week or so on I’ve essentially done the same thing as noted above. I used my diagnostics to trigger the starter motor which turns the car over. Thinking the start button could be part of the issue and at a cost of only £20 thought I’d replaced the stop start button (it was cracked anyway so no real loss here) but it hasn’t resolved the no start from the button press. All signs point to my ABS module not communicating with any of the ECU’s which look like, as I know one or two have alluded, they need an ‘OK’ from the ABS module for the vehicle to turn over from the start button.
Post #666273 9th Jun 2023 5:12pm
Westridge177
2011 Range Rover Vogue SE TDV8 Buckingham Blue
It would be great to know how this resolved. Did the guy end up breaking the car for parts. Or was it fixed.
I have exactly the same problem right now.
Post #711071 4th Feb 2025 10:41pm
tommartin
My ABS module was knackered. Replaced the module and everything came back up. Been fine since
Post #711074 4th Feb 2025 10:57pm
Westridge177
Thanks, but it was the original post that I’m interested in as I do not have any brake issues.
Post #711087 5th Feb 2025 10:20am
