![]() | Home > Maintenance & Mods (L322) > Foxwell NT530 |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
I’ve seen posts where people are recommending the nt530 for this very reason but I have now seen information where this feature has been removed from the new nt530 !! It’s probably best to contact foxwell directly |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It is not a headline feature of that device, if it was they would let you know as it would be super cheap to do that on multiple cars....
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1251 ![]() ![]() |
The cheap bluetooth units are good enough for what I need at the moment for £45 you cant complain. Delivery was about 1 week though. Worth getting just to open your world to the dark side lol
Hehehe I love how you say opening your world to the dark side 🤣 It is how it all started for me. And before you know it you’ll end up with an Autel 808 or something like that 🤣 |
Yes Bl4ckD0g
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 467 ![]() ![]() |
I own a few diagnostic readers for LR's including a Nanocom (mainly for TD5's), Britpart Lynx for the L322 (old but still brilliant, but won't do suspension calibration), the much discussed and recommended GAP BT IID as well as a Foxwell NT510 which I bought out of curiosity (plus I have Vauxhall / Opel software on that one in addition to LR).
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8349 ![]() ![]() ![]() |
You don't need to calibrate anything if you change a bag, the height sensor is separate and will trigger filling of the new bag to the same height... You only need to calibrate if it doesn't sit level at the correct height... ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 ![]() ![]() ![]() |
Thanks for all the replies so far folks and thanks for clearing up I don’t need to calibrate after a bag change etc 👍🏻
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Bit late to the party with this but I have the Foxwell nt 530 and it does list suspension calibration and it seems simple enough to do just read the instructions engine running dont open the doors hit ok and car will raise measure bottom of wheel rim to arch enter measurements into box for each corner hit ok job done but when car raises up it might be front up back down, left side up right not move, you name the combination and chances are it will do it (not on my own with this others have found the same). I now use BMW INPA software and lead (free download for software) along with one or two other people I know of, it works well the only down side if you would call it a down side is working out which buttons to press to get to calibration mode, mine is 2004 model L322. |
Bottom of wheel rim?? Are you sure? Then how does the NT530 know what size rims are on it? |
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 125 ![]() ![]() ![]() |
In theory it shouldn't matter what size rims are on or even where you measure from as long you measure from the same two points on each wheel - ground to centre cap, centre cap to wheel arch etc. Once you have all 4 measurements you pick one (x) and alter the three to match it so you need to +/- from each figure to match x and then visually check how level the car looks and repeat making fine adjustments until your OCD is satisfied 😀 2008 TDV8 |
I’d love to know what the measurement ground to centre cap will provide as a reference point unless changing the circumference of the wheel and tyres. Perhaps I’m missing something that is obvious to others.
