![]() | Home > Maintenance & Mods (L322) > Bi-Xenon shutter flicker and levelling questions |
Croker Member Since: 23 Mar 2021 Location: Granada Posts: 33 ![]() ![]() |
This shows the issue...
Headlamp Leveling - Dynamic Headlamp leveling [064BR] According to my VIN |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
wrong sort of replacement headlights ?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Have you tried getting it passed by just using the lever?
he does mention that the lever method isnt acceptable in spain,,, |
Yes I did read that, my question was has he tried it?
I got the adjustments sorted as one connector of the adjusters had popped out of the socket. I changed over the ignitor and Xenon power pack and the issue continued. I am waiting for the second unit to plug in and try so it has both the same type fitted (i.e with the motors) to see if its not liking just one. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
Not sure if it’s too late now, but I had an “engineer” open the units up and convert them to LHD spec. Saved ££’s on new or used headlights. Not sure how you’d find a local person able to do it. But it’s certainly doable! 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Just take off the stickers on the casing, drop the lever, the machine that checks the beam pattern will pass the flattened beam pattern |
“Flattening” the beam didn’t work for my ITV, the beam has to be “thrown” properly.
Maybe the Spanish are a bit tighter than the Portuguese then |
So today i replaced the units with standar LHD Bi-Xenon, no self levelling or directional, just as the original one were. Both of these are doing the shutter flicker and it only does it with the engine running. What can this be? |
I asked to day and it was a flat no! They have to be illuminating the verge too. |
You don't ask, you say yes they have been changed to lhd and try the test, it would have passed
